Idle validation switch
Old Sep 9, 2022 | 03:05 PM
MeTo's Avatar
MeTo
I need an idle validation switch. I know they are difficult to find. Would anyone have a source? I can DIY it if I need too?
PN: Cutler Hammer Eaton SS22BW32-330Y
Old Sep 9, 2022 | 05:06 PM
helifixer's Avatar
helifixer
https://www.riffraffdiesel.com/accel...ssembly-96-97/
Old Sep 9, 2022 | 06:01 PM
MeTo's Avatar
MeTo
Thanks, but I'm not buying the entire assembly. Contact switches are 20 or 30 dollars.
Old Sep 9, 2022 | 06:17 PM
RLXXI's Avatar
RLXXI
...and as plentiful as unicorn milk. Good luck finding just the switch, seems to me it's been vapor for over 10 years. Perhaps a salvage yard?
Old Sep 9, 2022 | 06:59 PM
MeTo's Avatar
MeTo
The OEM switch is not the only contact switch made. Their are lots of them out there. They just require a little modding of the pedal bracket.
In my case, I already have the pedal assembly modded to fine tune each switch. Modding the pedal assembly to accept a slightly different switch is minor. But, I guess it's not for everyone.
Old Sep 9, 2022 | 09:19 PM
Action4478's Avatar
Action4478
Wire it closed . The TPS is a different switch .
Old Sep 10, 2022 | 05:42 AM
MeTo's Avatar
MeTo
Can that be done with no ill effects? I'm aware the TPS and IVS are separate units.
Old Sep 10, 2022 | 08:44 AM
'74 Ford 250 CS's Avatar
'74 Ford 250 CS
Several years ago, I searched and searched for the IVS part number. You can't find it by itself. Seems crazy that's the case and I didn't like buying the whole pedal assembly, but glad I did. If you can mod a switch to make it work that's great. For me, it was money well spent not having to deal with a dead pedal when you need to accelerate.
Old Sep 10, 2022 | 01:03 PM
Action4478's Avatar
Action4478
As you most likely know , the IVS is a throttle override switch . It tells the PCM that its you holding the pedal where it is and is not just stuck . Most any micro switch (NO IIRC) could be modified to work .
Old Sep 10, 2022 | 04:01 PM
MeTo's Avatar
MeTo
As you most likely know , the IVS is very close toa throttle override switch . It tells the PCM that its you holding the pedal where it is and is not just stuck . Most any micro switch (NO IIRC) could be modified to work .
I just ordered one of these: EATON CUTLER HAMMER E47BMS04. It's very close to the OEM IVS and only $25.
Ford invested resources into incorporating an IVS. I have de***ted many things on my truck. The IVS will not be one of them.
Thanks to all of you for your input and have a good weekend.
bulla
Mar 10, 2012 09:55 AM
bowtied_micky
Modular V10 (6.8l)
Mar 20, 2011 06:54 PM
King0581
Jul 12, 2008 04:14 PM
farnorthdan
Nov 9, 2007 01:58 PM
kenny_barg
Mar 20, 2007 10:52 PM
