Sponsored by: Real Truck
Steering binding + outer tie rod issues.
Old Sep 8, 2022 | 01:10 PM
Additivewalnut's Avatar
Additivewalnut
1st Gear
I'm pretty new to heavy duty trucks. I got this truck from my father in law. Just gonna put that out there.
Today my 2001 350k mile work horse of a 7.3 decided it wanted to do something different and the clamp holding the drivers outer tie rod onto the steering rack(?) loosened itself and fell off while I was driving and I obviously lost all steering. I jacked the front end up, put the clamp back on, tightened, torqued. All is well. But now I suddenly have a binding issue. Seems like at any speed, when turning, I'll hit a wall and I have to push through it to get the full radius of my turn. I'm not sure if it's directly related or not but the truck has had some slop in the steering for a while.
Any ideas what that could be?
Old Sep 8, 2022 | 05:34 PM
user 195474726373's Avatar
user 195474726373
Is it in 4WD?
Old Sep 8, 2022 | 08:19 PM
RedNNBlue's Avatar
RedNNBlue
What you described is indicative of a seized u-joint on a 4wd front axle. I would start with checking them first.
Old Sep 9, 2022 | 07:07 AM
speakerfritz's Avatar
speakerfritz
my bet is the pitman arm is rubbing against your drag link bracket. pit man arm may have been bent slightly during yor loss of steering adventure....theres not a whole lot of clearence to start with.
if confirmed.....
replacing the pitman arm....would be a big PIA. needing a special puller. and you would likely damage the steering box during reinstall.
what you dont know, if the pitman arm is rubbing...until you remove both and inspect...is if either or are cracked.
Old Sep 9, 2022 | 08:52 AM
WWR's Avatar
WWR
Originally Posted by speakerfritz
{snip}
How's that, exactly?
And wouldn't it be more likely to bend a sector shaft than the pitman arm?
Still, I think before looking for zebras I'd chase horses. The front axle u-joint seems more plausible if 4wd and I'd look there first.
There's also no mention of if OP tried for a tape measure toe setting? If he just threaded it all the way on I'm not sure if this could cause his symptoms.....seems to me if toe is WAY out you'd reach a point where Ackerman almost fights each other left to right?? Maybe?
Old Sep 9, 2022 | 09:22 AM
speakerfritz
you don’t have to buy any zebra or horse feed stock.
it’s very easy to see if there are wear marks on the track bar mount in the area where the pitman arm would contact.
knottyrope
Aug 17, 2022 10:53 PM
73AlgonaMom
18
Mar 28, 2014 12:21 PM
Loaf4000
Australia Chapter
26
Aug 4, 2012 04:13 AM
hilltd69
Oct 19, 2007 10:01 AM
