Voltmeter question
Old Sep 7, 2022 | 07:21 PM
whisler's Avatar
whisler
Voltmeter question
Does anyone know if what purports to be a voltmeter on my1989 F250 is really a true voltmeter or just some glorified idiot light or ammeter?
Thanks.
Old Sep 7, 2022 | 07:35 PM
Conanski's Avatar
Conanski
It's a meter as in the needle will move but I don't think it's terribly accurate. Do you have the basic cluster or a tach cluster?
Old Sep 7, 2022 | 08:21 PM
Scndsin's Avatar
Scndsin
In playing with alternators, I've run a DVOM at the base of my windshield hooked to bat,
Driven & watched with different things running & it responds pretty accurately.
I'd say anything 5-10 degrees past center to right is 13+
Anything 5-10 degrees left of center is 12 & below.
Just my personal observations, not to be taken as fact.
Old Sep 7, 2022 | 09:58 PM
whisler's Avatar
whisler
I have the tach cluster (F250 Lariat XLT).
Old Sep 8, 2022 | 06:20 AM
Mudsport96's Avatar
Mudsport96
I did the same thing when I was having charging issues this summer. On mine between the R and M is about 11vdc, M is 14ish and 18 and red zone is most definitely 18vdc. Funny how a 1/8 inch can be 3 volts then it takes a half inch to do another 4. Wonderful variances in tolerance lol.
Old Sep 8, 2022 | 07:03 AM
Scndsin's Avatar
Scndsin
Yeah, mass manufacturing that was never suppose to live this long & be accurate.
But it somehow hangs in & does the job for the most part.
You stay over tween O-R consistently you probably got issues somewhere.
Old Sep 8, 2022 | 06:14 PM
whisler's Avatar
whisler
My dash gauge has actual numbers on it, but I wondered if they actually meant anything. Thus, the question!
Old Sep 8, 2022 | 06:44 PM
Mudsport96's Avatar
Mudsport96
Really? Pics?
Mine has i think 8 on the left and 18 on the right. And sandwiched between is NORMAL.
Old Sep 9, 2022 | 07:25 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My ‘89 doesn’t have all the numbers but there are marks for the numbers between 8V and 18V.
The gauges in my trucks are pretty accurate. It has let me know when the alternator was starting to go bad.
Old Sep 9, 2022 | 12:24 PM
rla2005's Avatar
rla2005
It appears to be a real voltmeter. How accurate it is may be a different story.
Old Sep 9, 2022 | 08:20 PM
whisler's Avatar
whisler
Mine actually looks like the one pictured by MY4Ford trucks.
Old Sep 10, 2022 | 07:37 PM
'89F2urd's Avatar
'89F2urd
I've always found the volt meters on these trucks to be accurate, if you know your alternator is working confirmed by a volt meter at the battery, then the dash reading is your reference. If you're driving and the gauge drops from normal, then you can bet that the alternator has failed. That, and the battery light will come on......
Old Sep 10, 2022 | 07:42 PM
whisler's Avatar
whisler
Thanks Guys. Looks like it is a real gauge, so all is good.
Old Sep 11, 2022 | 01:42 AM
AuroraGirl's Avatar
AuroraGirl
Its not linear is why
Im not saying its right but its how they did it, which is frustrating to all hell
quitcrab
Mar 24, 2017 06:01 PM
FordmanNJ
All Things Towing
Aug 7, 2015 11:01 PM
superduty4x4
18
Jul 22, 2009 09:48 AM
speedracer54729
Mar 21, 2008 08:36 AM
