Smokers Only
Old Nov 11, 2003 | 02:48 PM
Malone Loner's Avatar
Malone Loner
O-rings
No I smoked cigarettes for 10 yrs and could never figure it out! I've seen friends do it though.
I quit cigarettes, but I still try; kind of hard to blow smoke rings after a bong hit!! Yea, I just looked at the clock here it's almost 4:20pm!! Gotta go later!
Old Nov 11, 2003 | 03:10 PM
discorabbit's Avatar
discorabbit
Ex-g/f took me to a scuba diving pool once, only once. An instructor took me down to the bottom of the pool, and he laid on his back and blew "water" rings. About 30-35 feet under water and when they reached the surface they were about Ø10. You could see the water turning around the air. I was amased.
Old Nov 11, 2003 | 03:41 PM
reever's Avatar
reever
OK, I admit it, I can do it. No tongue involved. Make your mouth into an "O" shape, with smoke in mouth, jut your jaw forward and close in a snapping motion. The smoke will be pushed out in a small "O". Watch the ring.
Da*n, almost sounds like a technique I saw in a movie once.....
reever
Opiewan's Avatar
Opiewan
why didnt your girl friend teach you how to blow ?
Old Nov 11, 2003 | 04:29 PM
2Bowers's Avatar
2Bowers
Other Bower can blow smoke rings. It's as described above, although she says you gotta close the back of your throat and then puff the air out. (? I can't do it, just repeating.) Also make sure the ceiling fan isn't on. She says works best someplace that has heavy air, like a bar or lounge, so the ring just hangs in the air.
Old Nov 11, 2003 | 07:16 PM
88grandmarquis's Avatar
88grandmarquis
I don't smoke, but my old brown '86 F-250 could blow smoke rings when it was cold outside. I'm not kidding. It had a 460 in it with that big single exhaust. It was the coolest thing. It would idle rough (kink of a chug) and evertime the engine got into a rhythm, it would blow these perfect smoke rings. Too cool.
Old Nov 11, 2003 | 07:46 PM
Bargod's Avatar
Bargod
I'm at work and had to go outside and try this. I should've read the rest of the thread first, doesn't work too well when the wind is blowing. Although, I've never been able to do it before, why should now be any different?
Old Nov 11, 2003 | 09:15 PM
wabiker's Avatar
wabiker
....Fill yer mouth full of smoke, form an "O" with yer lips, open yer jaw then pop it closed (while maintaining the "O")...while gently exhaling....the bigger the "O", the bigger the ring...
...Now as for Dragon rings, thats a whole different story...
Old Nov 11, 2003 | 09:22 PM
2Bowers's Avatar
2Bowers
(Other Bower here)
I took firebreathing lessons once upon a time. (It was a Renaissance Faire thing.) I decided I liked my eyebrows, and did not like the taste of lighter fluid. I was OK at it, but the truth is that most girls cannot naturally spit. It's a guy thing I guess, I had to work at it.
However it's easier for girls to blow smoke rings...look at yourself in the mirror when you try it, you should see why... ;-o
Old Nov 11, 2003 | 09:54 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
When I smoked I learned how to do it. I quit over a yaer ago and can't honestly remember how to do it. I remember that once I did learn it it was pretty easy. You have to be in some still air though. Can't be anywhere with any sort of air moving otherwise it messes up the rings.
ShallRemainNameless
68
Dec 21, 2007 07:58 AM
79pos
16
Oct 19, 2005 12:46 PM
aerocolorado
Apr 23, 2005 07:57 PM
pistol pete
Dec 14, 2004 11:37 AM
brad76f250
Jul 5, 2004 06:07 PM
