Sponsored by: Real Truck
Hot start issue
Old Sep 4, 2022 | 08:07 PM
TJKing's Avatar
TJKing
2nd Gear
Hot start issue
I’m having a problem with my 07 Superduty 6.0 automatic not restarting when it gets hot. It will just click, doesn’t crank.
iI’s not EVERY time, but pretty regular.
The batteries are new and have been load tested.
The starter relay and ignition switch were replaced.
The starter and solenoid have been replaced.
Continuity of the battery cables has been checked.
SOMETIMES, I can cycle the gear selector, and it will start.
SOMETIMES, if I cycle the key a couple times quickly it will start.
But MOSTLY, I leave the key in the on position, separate a plug on the passenger fender and touch that plug to the battery and it cranks and starts.
Given everything that’s been done, and having looked at the starting circuit diagram, I believe the only thing left is the neutral safety switch or digital gear position sensor or whatever they call it.
Opinions?
Old Sep 5, 2022 | 12:11 PM
Djosbun's Avatar
Djosbun
A continuity test of the battery cables is meaningless. A can cut 48 strands of a 50 strand cable and it’ll pass continuity. You need to test if it’ll carry amps.
Get out your multimeter and perform a voltage drop test on both positive and negative cables. Corrosion lives under the sheathing and can create a massive amount of resistance.
— Dave
Ddaybc
Jan 5, 2019 03:57 PM
excelstillmore
Jun 27, 2016 08:00 AM
Littlejon
1997 - 2003 F150
Mar 21, 2016 12:19 AM
73strokin
Oct 28, 2007 09:21 AM
commkxxx
1983 - 2012 Ranger & B-Series
Jul 21, 2005 09:40 PM
