Windshield washer fluid pump not working.
Old Sep 3, 2022 | 07:45 PM
stormrider151's Avatar
stormrider151
I have a 2018 F250 SD, 6.2 gas, crew cab. The windshield washer pump is not working and I'm in search of the fuse for it. I've Googled, checked the manual and gone through the forum search and can't find it anywhere. Hopefully you guy's know where the illusive little bugger is. The wipers work fine. The switch is good. There is no sound at all coming from the pump. Thanks.
Old Sep 3, 2022 | 08:03 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Those pumps do fail from time to time.
Also possible the line is clogged or the inlet filter on the pump is clogged.
Old Sep 3, 2022 | 08:08 PM
stormrider151
I checked the lines and they are clear. I just need a fuse to check before I pull the pump out. It's a small thing I know but around here it's a gotta have.
Old Sep 3, 2022 | 08:13 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I looked at three different fuse lists for 17-19 trucks and didn't see any fuse listed for the washer pump.
I would connect a DVOM and see if there is power to it when the button is pushed.
Old Sep 3, 2022 | 08:29 PM
stormrider151
I guess so. I was hoping to avoid having to access the pump. It's not difficult just time consuming. And I don't have much of that. Thanks for your help.
slowpoke17
Sep 26, 2021 03:35 PM
PNGento
Mar 5, 2021 07:36 AM
stvneil
2015 - 2020 F150
Sep 25, 2020 04:54 PM
WINGNUT-
15
Jul 31, 2010 10:49 PM
madspence2
Oct 14, 2004 03:12 PM
