Truck Bed Rust
Old Sep 1, 2022 | 03:11 PM
chzuck's Avatar
chzuck
Truck Bed Rust
I wonder how many 2005 F150 trucks had their bed rust through because of Ford's dumb or cheap idea? At the front right corner, above the muffler Ford fastened a piece of insulation to the bottom side of the bed. I now have a hole because of moisture trapped there over the years. Thinking of removing it and fastening a piece of flat galvanized steel from the front bed support to the next bed support. That would give a good air space between the bed underside and the piece I would install. It would act as a heat shield for the muffler and would not trap moisture. Anyone else have this problem? Other ideas?
Old Sep 2, 2022 | 09:05 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Well crap...I bet, we will now...thanks again Ford
Old Sep 4, 2022 | 04:11 PM
chzuck's Avatar
chzuck
Some photos of the heat shield I added when I removed the rust causing insulation.
Heat shield with an air space above that is between the front two bed supports.
Piece of insulation
The piece of insulation was glued to the underside of the between between the red lines and fit between the 2 front bed supports.
Hole in the bed at the right front corner near the front bed bolt hole.
Old Sep 4, 2022 | 06:15 PM
torq'ta 5 8
engineers are getting worse, at great ideas, on the 04-08 trucks
Old Sep 4, 2022 | 08:04 PM
tbear853's Avatar
tbear853
You mean that one is supposed to drive them in rain or snow or sleet to even get them wet there?
I saw that insulation years ago, no damage ... but it is shielded ever since then.
Old Sep 7, 2022 | 03:13 PM
ahmad_f150's Avatar
ahmad_f150
angle grinder + fluxcore welder = happy truck owner
rd65
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Feb 9, 2022 09:35 AM
pcorbino
Jan 17, 2022 07:37 PM
grinnergetter
Apr 1, 2014 02:26 PM
Shawn66mcl
Sep 29, 2011 09:13 PM
