Gear ratio change
Old Nov 11, 2003 | 09:03 AM
ANIMAL's Avatar
ANIMAL
Gear ratio change
Hey guys! I have a '79 F150 4x4 with 35" tires and 3.50 stock gears. I would like a lower gear ratio. I do mostly street driving and some off-road (snow and mud). I live in the hills so I do climb some hills on the highway coming home and the truck is constantly down shifting. The engine is the 400 and the axles are the Dana 44 and the 9". With the tire size what do you guys recommend for a gear ratio and how much can I expect to plunk down at a shop to have both axles done? Thanks for your help
Old Nov 11, 2003 | 12:51 PM
javi2001's Avatar
javi2001
4.1:1 but depends on your tranny model...
Old Nov 11, 2003 | 06:07 PM
ANIMAL's Avatar
ANIMAL
Sorry, its a c6
Old Nov 18, 2003 | 04:54 PM
javi2001's Avatar
javi2001
Well, this configuration will give you some extra pulling torque, but you lost some highway top speed, but It is not be a problem because your high tires...
Regards;
Old Nov 18, 2003 | 06:16 PM
MustangGT221's Avatar
MustangGT221
Well, you'll want to know what RPM for a given speed you'll be running, so use this formula
MPH x GEAR RATIO x 336 / Tire Size
That will give you the RPM per MPH in 3rd gear for your C6.
You'd be running about 2500 rpm if you got 4.10s at 65 mph, which is a tad high, but it's all in how you want to run it.
Ultraboy
Mar 17, 2016 11:51 PM
FireBlue
Jan 25, 2016 04:01 PM
Rusty830
1997 - 2003 F150
Mar 20, 2015 07:10 AM
Shadow944795
18
May 20, 2014 06:56 PM
