fuel starvation
Old Aug 28, 2022 | 08:16 AM
broncorckcrwlr's Avatar
broncorckcrwlr
fuel starvation
I have a 1995 F150 with the 5.8. Over the last several months the truck has become increasingly hard to start due to fuel starvation. Once started it still has fuel issues for a short time until what seems like the air gets out of the fuel line. I have changed the fuel filter and the f/i controller or whatever you call it under the hood with no change. I have come to realize that if you just turn the key and crank it can take a long time to start if ever but if you crank it, turn the key off and then crank it again it will start but still has starvation issues when you start to drive. The truck has dual tanks and it doesn't matter which tank I'm drawing out of it's still the same issue. Any ideas appreciated.
Old Aug 28, 2022 | 09:40 AM
Conanski's Avatar
Conanski
You need to get a fuel pressure tester and measure pressure at the rail, it make no sense to guess at these things
Rusty Shacklefurd
13
Aug 9, 2021 01:36 AM
LittleBlue94
Mar 12, 2013 08:06 AM
thejean
6.7L Power Stroke Diesel
55
Nov 17, 2011 07:55 AM
70Bronco
Oct 23, 2004 04:45 AM
supercab blue
Mar 11, 2004 07:16 AM
