Weights
Old Nov 11, 2003 | 05:54 AM
flatliner's Avatar
flatliner
Question Weights
How many of you guys know what your truck weighs, I mean actually weighs, not what the sticker says. I built a high-boy to race with this year and after removing everything I could I'm still weighing in at 4720lbs. I'm the heaviest truck on the track. Looking at building an F-150 this year to get the rest of the weight off. My goal is to get down to 3800lbs. w/driver (200lbs.). Is it possible to ge that light with a late '70s 4X4? I have to keep the full factory body with no noticeable gutting. The fenders can be trimmed for tire clearance.
The drivetrain includes a 460, C-6, Np-208, 9" and Dana 44.
Old Nov 11, 2003 | 06:17 AM
F150daniel's Avatar
F150daniel
my 2WD '79 F100, 302, longbed 4,700 lbs, my GVW is 4,800lbs
Old Nov 11, 2003 | 06:26 AM
F150daniel's Avatar
F150daniel
if you want to go all out and get a fiberglass cab and bed.
http://www.usbody.com/WhereQualityComesFirst.htm
Old Nov 11, 2003 | 07:44 AM
flatliner's Avatar
flatliner
Can't use fiberglass except for the hood.
Old Nov 11, 2003 | 12:26 PM
drunkenmonk's Avatar
drunkenmonk
F 100?
Old Nov 11, 2003 | 12:48 PM
flatliner's Avatar
flatliner
How much difference is there between a 100 and a 150. I have a 2wd f-100 I though about converting to 4wd if it would save weight.
Old Nov 11, 2003 | 01:36 PM
F150daniel's Avatar
F150daniel
the badge and rear springs.
Old Nov 11, 2003 | 01:42 PM
F150daniel's Avatar
F150daniel
3600 lbs
find a beatup rusted out bronco and make a tube chassis.
Old Nov 11, 2003 | 01:44 PM
Texan1983's Avatar
Texan1983
my 4x4 f150 weighs in at 5200 pounds with me, two full gas tanks, tool box with tools, heavy duty bumpers front and rear, and a winch. i don't think you could get that light with an f150. but maybe, i don't know
Old Nov 11, 2003 | 04:12 PM
flatliner's Avatar
flatliner
I can't run a tube chassis but I do plan to use lightweight crossmembers only where needed and the frame will be drilled to remove weight. Only a front bumper is required and it will be cut short. Aluminum spool in rear, aluminum t-case, lightweight disc brakes front and back and the lightest wheels possible. I also plan to cut out all the body braces that I can. I will leave only the supports needed. Check out the high-boy in my gallery and see how I got it down to 4700. I could get it lighter but I don't think I could get it as light as a f-150.
