Larse steering gear
Old Aug 22, 2022 | 05:49 AM
Sunnysideup's Avatar
Sunnysideup
2nd Gear
Larse steering gear
Hi all,
I have a ‘77 Ford F-250 super cab with a leaking steering gear. I’ve already changed the seals but no luck. I’m looking at steering gears on Rockauto and seen a Larse quick ratio steering gear. Part # 1061.
has anyone tried one of these and is it worth switching to or just getting a standard replacement. I’m not sure if the input splines are the same count or if a new, different rag joint is required.
just looking for some input before I pull the trigger. Thanks in advance
Old Aug 22, 2022 | 08:31 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes once the box gets worn out and the excessive play transmits to the housing, new seals are only a temp fix. So you are looking into getting this one? https://www.rockauto.com/en/moreinfo...027264&jsn=270
Maybe cheaper here? https://www.summitracing.com/parts/lsc-1061
If I pull the trigger on a new/reman steering box, it will be for a Red Head or Blue top.
https://www.redheadsteeringgears.com...4aAh8OEALw_wcB
https://bluetopsteeringgears-com.3dcartstores.com/
This is about the only thing you can do when the housing it worn.
Our re-manufacturing process:
  • Machining out the housings and installing needle bearings
  • Flame-spraying or replacing the shafts as needed
  • Installing new control valves on some applications
  • Custom fitting each worm & piston assembly with special ordered, precise over-sized ball bearings.
Other things we do to produce a top quality product include:
  • Install every sector shaft on a lathe to check for straight and true
  • polish the sealing surface to a higher polish than new.
Old Aug 22, 2022 | 09:17 AM
Sunnysideup
2nd Gear
Thanks for the reply, I see the quick ratio and regular is only 1/2 a turn difference from lock to lock, and this thing is far from a race truck so I’ll probably just stick with a factory replacement style and save a few bucks.
I didn’t figure the new seals would last, but for 20 bucks it was worth a shot.
Hyakkimaru
Jan 8, 2022 09:38 PM
jgavac
Jun 14, 2017 05:24 PM
invstr55
Sep 24, 2016 10:37 AM
99expyTN
6.4L Power Stroke Diesel
Oct 2, 2014 08:12 PM
