Added Adaptive Cruise Control (ACC) to 2022 F-250 6.7L Lariat Value Super Cab
#196
I have been following this post and want to add this to my truck. I wonder if anyone here can advise on my questions about the config of my current truck and can it be added even with some major adds. What major adds have you done? No way to tell if it will affect adding the ACC.
2022 F250 XLT 7.3 Crew Cab
- Does NOT have Factory Fog lights, but I have located a bumper take off with factory LED's. These are NOT needed for the ACC. There was some question early on, on my part, about the harness for LED versus Halogen fog lights being different but that was later resolved when I found the harness was exactly the same for both types. You could use the harness I referenced (with fog light connectors) and just not use the fog light connectors (tape them off). The reason the harness was questioned is because the same harness feeds the ACC module (radar sensor behind the grill) and the fog lights. Your factory harness, without ACC, will not have the ACC connector but would normally have fog light connectors. You probably need to be sure you have the large connector coming off the truck that is needed to plug the harness into since your truck didn't come with fog lights and may not even have the harness.
- Does NOT have the 8" Productivity Screen, but am wanting to add. As far as I know, this is mandatory for the ACC mod. See Rapid Red 7.3 posts about changing his XLT to the 8" screen. I would do this before I started gathering ACC parts in case this become a hurdle you can't get over.
I know these are two major upgrades, are they are required before I get started on the ACC parts collection?
Thank you, This is a great thread, it appears most of you started with trucks that had these upgrades.
Thank you! Good Luck!
#197
Sorry, by major adds I meant the Fog lights/bumper and the 8" cluster. But since you asked, I have added the floor console (from the jump seat) with all power/sync working, added the keypad, added hill descent, added cargo lights/switch (oem) and some of the usual forscan changes to get rid of dings.
Thank you for the feedback and answers. I will see if i can find the connector/harness you are speaking of. Any pointers to where I might look?
I will review Rapid Red 7.3 post.
#198
edit: It is right behind the Prius catcher. Pictures attached.
This is the 16 pin connector with ACC/fog light harness attached. Looking from passenger side toward the driver side.
The 16 pin connector with harness disconnected. Looking toward the rear at the inside of the driver side frame rail.
#200
Got this completed over the weekend. PDF instructions were spot on and had it working very quickly. One thing to note is on a truck with the factory winch many of the acc brackets do not need to be purchased. With the winch already in place this only cost me about 600 for all new parts, cheaper than the $740 it was to add this option when ordering the truck new!
#201
#202
#203
Good Luck
#204
#205
If you get this to work, you would be a rock star to several of our members with 23's that have considered adding the ACC if you would do some sort of post or writeup detailing the parts you needed and the FORScan changes you made.
#206
Hello @Lariatdriver ,
I have slowly started to gather my parts for the ACC add, I started with a bumper with Halogen Fogs (I missed a local LED version), so I am trying to confirm the wiring harness. In your V4 document you list LC3Z-15K867-A ( https://www.tascaparts.com/oem-parts...ss-lc3z15k867a ) as the harness that will work with LED or Halogen fog lights. I was about to order it and I noticed that it lists only working with 2020 to 2022 F350 all trims/all engines. It says it won't fit my 2022 F250 XLT CCSB 7.3L, but that seems odd. I have looked for a similar part number for an F250, with no luck.
This harness will have the 16pin main connector, two fogs and the connector for the ACC sonar, correct? I don't want to order a harness that doesn't do ACC, but does fog lights.
Can you confirm this part number LC3Z-15K867-A is good in an F250 application in your experience?
I posted a similar question in a fog light thread and then realized I needed to make sure I bought the right part for my end goal.
Thank you!
Thank you!
#207
Thank you!
Thank you!
I did find in several instances where a part was said to fit say a 350 but not a 250 but it was actually the correct part for both. As long as it isn't suspension related, you will probably be fine with most parts fitting a 350 or 250.
F350Loui
61
07-25-2023 09:43 AM
rfairwea
Ford Truck Parts for Sale
02-11-2013 10:55 PM
