Flat ground Towing 4x4
Old Aug 20, 2022 | 07:47 PM
AngryTexan's Avatar
AngryTexan
1st Gear
Woot 1st post.
I have a 05 Excursion I need to cross country tow. Unfortunately I don't have access to a trailer to get it off the ground, but fortunately I do have access to a tow bar that is rated for 10k from a buddy of mine.
My question is: Can I just drop the driveshafts ratchet them gals up and be on my merry way? Will the axles leak with the removal of the driveshafts? Any input would be appreciated.
The pain in my life I'll be dragging.
Thanks.
Old Aug 20, 2022 | 08:07 PM
00t444e's Avatar
00t444e
Just have to disconnect the rear, and leave the transfer case in 2wd with the hubs unlocked.
Old Aug 20, 2022 | 10:25 PM
EXSwap's Avatar
EXSwap
^^^this. Personally, after having set up my X for flat towing behind an RV, I’d just pull the entire rear driveshaft. They are heavy and there’s no real great way to tie one up (at least I don’t think so) for a long haul. It’d be easier to just pull it and not have to worry about it coming loose.
Old Aug 20, 2022 | 11:21 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
i second removing the shaft completely, My dad and I pulled a blown motor from a dodge 2500 for a friend of his, it was very much not taken care of and actually had rust on the cylinder walls, long story short they disconnected and tied up the shaft tail to flat tow it across town to a engine shop, well, the shaft fell down from the front, caught the ground and launched the rear half of the truck up in the air, cratered the truck bed upwards from below and broke all kinds of stuff, launched the old motor from the bed onto the sidewalk where it tumbled a short distance, all before it had even made it a mile. He had told them just before they left that he strongly recommended they go rent a u-haul trailer, they ended up scrapping the truck after that.
Old Aug 21, 2022 | 06:58 AM
00t444e's Avatar
00t444e
Common sense goes a long way, you disconnect it from the rear not the front, it will turn if you leave it connected to the axle.
Old Aug 21, 2022 | 11:49 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
You misunderstand, they did disconnect the rear, but then the front vibrated out of the back of the transmission, and fell down, and well, became a ballistic trebuchet, or catapult.
jtrux
Mar 2, 2019 11:25 AM
ford4her
All Things Towing
May 26, 2016 12:50 PM
Headviking
Jul 18, 2009 06:37 PM
armybronco2
Bronco II
16
Jan 7, 2007 12:44 AM
IBeam
General Automotive Discussion
16
Feb 17, 2006 09:38 AM
