Ford Removed Ability to Make Changes to IPC in FORscan?
I recently put in a 60gallon S&B tank. The dealership tried to change the tank size and could not. After many back and forth with Big Ford - Big Ford sent them a letter stating that dealers are not allowed to change tank size and Ford will not support that functionality. SO - it looks like Ford has changed software setting to disable the IPC module, for dealers/service centers.
I ordered the scan tool from S&B and tried it, no luck. I spent time on the phone with them, multiple firmware updates/changes, no luck. Still can't change the tank size. Auto Agent 2.0 does not see the tank size and will not allow you to run anything involving the tank size. I then got FORscan and their recommended cable, loaded it and ran every version of FORscan going back to 2017. Still no IPC module.
Does anyone know how to get the IPC module to come up? Is anyone else having this issue? It is great to have a bigger tank - but I would like to set the tank size and can't understand why Ford has removed the ability from their service departments AND from other OBD2 tools.
Thanks!
Thanks!
The following users liked this post:
Thanks!
Thanks!
Also sent you a PM.
edit
check that. You don’t have enough posts for pm yet
ZooDad
so Im guessing the OP has a 20+ year vehicle.....if so...I dont think the IPC is the only thing not accessable in 2020+ year vehicles...the PCM software is encrypted. typically encrytion means software keys are needed that dynamically change. tokens are used to generate the keys. example.....IDS serial number+employyee number+dealer number and wiz bang a dynamic encruption key is generated good only for that session.
Thanks!
Thanks!
https://www.f150forum.com/f118/forsc...-truck-348987/
FYI, I took ZooDad's advice and upgraded my connector. I purchased an EX OBD Link and I updated my computer to the latest version of FORScan. Once I plugged it back in I was able to update my fuel tank size. It appeared that I could make additional changes as well.
Hopefully this will help others who are trying to make changes (Thank You ZooDad)!
The following 4 users liked this post by rtripp:
here you go
http://OBDLink EX FORScan OBD Adapte...a.co/d/654gSda
ZooDad
The following 2 users liked this post by ZooDad:
There is a Forscan guru by the handle of Livnitup who I have seen on this forum but he is way more active on the Ford F150 Forum. Hit him up - he will know more than anyone about this.
@B-ManFX4 you can tag anyone by using the @ sign before typing their handle. A few letters in and the correct one will show up. Click on it and it adds a tag for the user.
