93 F150 e40d won’t shift?
Old Aug 19, 2022 | 09:03 PM
Jtheobald90's Avatar
Jtheobald90
2nd Gear
My 93 F0150 was shifting hard along with me having to let off the gas so it would shift. However it will not shift past first gear while in drive. But I can manually **** it into second gear using the gear shifter.
Old Aug 19, 2022 | 09:55 PM
Prototypemech's Avatar
Prototypemech
Reading the codes is always the first step when you have a problem like this.
Throttle position sensors and transmission manual position lever sensors wear out over time and can cause a no-shifting problem. Luckily, these parts are cheap and easy to replace if they're bad.
Old Aug 20, 2022 | 08:31 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Follow the steps as written in the previous post. DO NOT take the "shotgun" approach of throwing parts at it hoping to replace the faulty component. You must do some diagnostic testing or your wallet will get empty and you will be frustrated very fast.
Old Aug 20, 2022 | 12:39 PM
Jtheobald90
2nd Gear
I got 311, 116, 332, 536. None of them seem to be transmission related.
Old Aug 20, 2022 | 01:30 PM
My4Fordtrucks
311 Thermactor air : engine running
116 Coolant temp higher or lower than expected: engine off or running
332 Insufficient EGR flow : engine running or stored
536 Brake On/Off circuit not activated : engine running or stored
These are or could be engine running (KOER) results so did you do the key on engine off test (KOEO) self test first and you get the system pass code 111? You must do the engine off test and repair any faults before moving onto the engine running test. Coolant temp could be that the truck was not up to operating temperature while code 536 could be operator error. Did you press the brake pedal during the engine running test when prompted?
Old Aug 21, 2022 | 12:36 AM
Prototypemech
Interesting that you don't have any transmission codes. I'm curious if you've lost electrical power to the transmission or maybe the transmission wiring harness has chaffed against something and damaged the wires.
Check the fuses under the hood and by the driver's knee to ensure none are blown. Then, crawl under the truck, under the passenger side door and inspect the harness and electrical connector for damage. The exhaust pipe runs nearby and it might have melted something.
Old Aug 21, 2022 | 08:18 AM
rla2005's Avatar
rla2005
Transmission related codes are stored in Continuous Memory. Run the Key On Engine Off (KOEO) tests and Stored Code display.
With no power to the solenoid pack I believe 4th and Reverse will work.
Old Nov 25, 2023 | 10:47 AM
kingary49's Avatar
kingary49
4wd Low
Having the same problem. My 93 F150.
Old Nov 25, 2023 | 02:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What codes do you have stored in the PCM? Here is how to read them: www.troublecodes.net/ford
Old Nov 25, 2023 | 03:14 PM
My4Fordtrucks
kingary49 has started the thread “transmission shift problem” for this issue.
mzuern
Jun 6, 2022 12:32 PM
JMorrison74
Apr 8, 2022 07:39 AM
Highcountry30
Nov 6, 2016 11:36 PM
918eva
Jul 19, 2010 10:04 PM
rabeb
Feb 7, 2009 03:03 PM
