Tachometer problem
Old Aug 19, 2022 | 06:35 PM
FordWindsorLife's Avatar
FordWindsorLife
Tachometer problem
Hey all, I recently bought a instrument cluster from a 1992 F250 7.3idi that had a tachometer. I swapped it into my 1993 ford f250 351w. I know that it see's it, when I start up the vehicle that tach moves a hair, and when I rev it, it moves a small amount, however it will not move past and or even close to 500 rpm. It just does little nudges from 0 - 200 rpm (probably). I have no idea what to do, any help would be very much appreciated.
Old Aug 19, 2022 | 06:59 PM
cannothinkofaname's Avatar
cannothinkofaname
wouldn't the tach on a diesel only go to 4000RPM? The tach on my inline six goes to 6000RPMs. I would assume the tach on a v8 would also go to 6000rpms.
Maybe they are incompatible..
Old Aug 19, 2022 | 09:58 PM
SFaulken's Avatar
SFaulken
I do not believe the tach out of a Diesel equipped truck will work in a Gasoline truck. Diesels do not have Ignition systems, so they derive their tachometer signal by other means (oftentimes pulling a signal off the alternator), and I'd bet good money they Diesel Cluster has absolutely no idea what to do with the ignition signal from the Spark ignition setup.
That you're seeing any activity, at all, is just due to the fact that it's expecting a 12VDC signal, but the signal you're feeding it isn't useful.
Old Aug 19, 2022 | 10:09 PM
Prototypemech's Avatar
Prototypemech
IDIs get their tach signal from a small hall effect sensor located on top the timing gear cover. I imagine there about 40 teeth on that gear so 40 pulses per revolution. The gas trucks get their ignition signal off the ignition module, I think, which is 4 pulses per revolution. Which explains your 10:1 ratio. I'm surprised it recognizes the signal at all. Unless you wanna program an Arduino board to boost the pulses 10 times, it would be a lot easier to get the instrument cluster for a gas model.
Old Aug 20, 2022 | 09:18 AM
My4Fordtrucks's Avatar
My4Fordtrucks
From a 10 year old thread about instrument cluster compatibility:
Old Aug 20, 2022 | 12:11 PM
FordWindsorLife
Well then it looks like im the idiot, I just ordered a gas tachometer. The diesel Instrument cluster had a 4 pin connection available for the tachometer, however the diesel tachometer was only taking advantage of 3 of them. The gas tachometer had all 4. So I had already purchased it as of the first comment. *facepalm*. Well if it works great....will let you guys know.
Old Aug 22, 2022 | 05:35 PM
FordWindsorLife
Update: Alrighty for all those wishing to know, a Gas Tachometer will work in a Diesel Instrument panel, on a Gas truck of the same year as a diesel.
This is my gift of idiocy to you all!
Old Aug 22, 2022 | 07:24 PM
Prototypemech
You swapped the gas tachometer servo and needle and installed it into the Diesel instrument cluster?
Old Aug 22, 2022 | 07:29 PM
My4Fordtrucks
I’m also not sure what he did.
Old Aug 22, 2022 | 07:36 PM
SFaulken's Avatar
SFaulken
Uh, you don't exactly have to disassemble the tachometer itself, if I remember the cluster in my '92 properly, the Tach comes out as a unit, the Speedo comes out as a unit, and I think like Temp/Batt and Fuel/Oil pressure come out as two little units. It's modular, it wouldn't surprise me, if you could take the tach module out of a Gas cluster, and plug it right into a Diesel Cluster. I don't know that for a fact, but I'd venture a guess, the actual construction of the "backplane" is identical.
Old Aug 22, 2022 | 07:57 PM
FordWindsorLife
"You swapped the gas tachometer servo and needle and installed it into the Diesel instrument cluster?"
Sorry for the confusion, yes I did this.
Old Aug 22, 2022 | 08:00 PM
Prototypemech
Isnt the numbering all messed up too, since the diesel tach only goes to 4k? Sure, the needle moves, but its not accurate... or maybe it is. IDK, asking you for clarification. Maybe a picture.
Old Aug 22, 2022 | 08:05 PM
FordWindsorLife
I put gas tachometer in diesel instrument cluster on a gas truck.
File Type: mp4
FordWindsorLife
And yes I know my truck has a vacuum leak. It takes 40 seconds for engine to go to idle.
Old Aug 22, 2022 | 10:22 PM
My4Fordtrucks
So you put the gas tachometer in the diesel cluster. Got it now
LARIAT 85
Apr 17, 2009 09:33 PM
6.9 Diesel
Jul 28, 2008 12:21 AM
NNBlackGT
Nov 26, 2007 09:58 PM
jhasz
Mar 3, 2003 01:39 PM
pcman
Nov 27, 2001 10:52 PM
