Water issue
Old Aug 18, 2022 | 03:15 PM
BlueRidgeMan's Avatar
BlueRidgeMan
Water issue
I somehow have water coming into the cab and can’t figure out where it’s coming in. Water is pooled up under the carpet in the footwell on the front passenger side and soaked through. I never noticed it until it started smelling musty in the truck. I removed the carpet and used a wet vac. It’s mostly wet in the front with water also in the cable tray below the sill.
I never noticed water coming down the pillar and don’t recall leaving a window open in the rain.
has anyone else had this problem? Any ideas where the water could be coming in? I might have to sit in the truck while my wife sprays water in various areas outside.
it’s a 2019 crew cab F350 SRW
thanks,
jim
Old Aug 18, 2022 | 03:36 PM
DaveyMac's Avatar
DaveyMac
I went thru this in the spring on my 2021 F350
GAZZILLA's Avatar
GAZZILLA
Are you sure it’s not antifreeze? In the old days the heater core would leak there.
Old Aug 18, 2022 | 03:40 PM
DaveyMac's Avatar
DaveyMac
My dealer spent 4 months trying to track this down, not until I found this video were they able to fix my truck.
Old Aug 18, 2022 | 04:26 PM
Romark's Avatar
Romark
I had this happen on a car I had. Turns out the A/C condensate drain was plugged and was backing up into the cab.
Old Aug 18, 2022 | 04:28 PM
BlueRidgeMan
definitely not antifreeze. I was wandering if it could be condensate from the A/C.
Old Aug 18, 2022 | 04:30 PM
BlueRidgeMan
did you have wet carpet in back, too? I think mine is only in the front….or could it travel in the cable tray?
morehouse7's Avatar
morehouse7
https://static.nhtsa.gov/odi/tsbs/20...68762-0001.pdf
Old Aug 18, 2022 | 04:36 PM
4wd6.7L's Avatar
4wd6.7L
This would be my first suspicion since you are seeing it on the passenger side, and there is that known TSB posted above.
I purchased the elbow that's used in the TSB just in case I experience that problem.
Old Aug 18, 2022 | 05:03 PM
BlueRidgeMan
Thanks, guys. Two good leads to investigate. I’m out of warranty for normal body stuff so I’m running this down myself.
Old Aug 18, 2022 | 05:09 PM
manicmechanic007's Avatar
manicmechanic007
That HVAC drain has been a problem for years
Use whatever you can to direct the water down and away
They used to leak on the #4 plug and cause a miss 97-03
Now they just soak the carpet
You put a used spark plug boot on there for 50 cents and be done with it
Old Aug 18, 2022 | 06:17 PM
SoCalJ's Avatar
SoCalJ
I had water coming out of the A pillar trim on my '22 without a sunroof. Turned out to be a bad body seal under the black trim where the roof and the door surround meet.
Good luck on yours!
Old Aug 18, 2022 | 10:46 PM
number9xd's Avatar
number9xd
Take a look at this thread OP
https://www.ford-trucks.com/forums/1...or-soaked.html
Old Aug 19, 2022 | 04:09 AM
DaveyMac's Avatar
DaveyMac
Old Aug 19, 2022 | 08:41 AM
BlueRidgeMan
yeah. Good video. I’ve watched his videos before and they’re good. I have the part on order. The carpet is so soaked that I cut out the nasty parts. I’ll have to piece together a replacement but don’t want to replace the entire carpet. Way too much messing around🤪
