VIN number details
Old Aug 14, 2022 | 08:10 AM
Tul01's Avatar
Tul01
VIN number details
Hi guys, picked up a shortbed frame the other day, it is 3rd hand since the original project so I’m not sure on the details. Would one of you be able to decipher details to confirm what I bought? Thanks as always.
Old Aug 14, 2022 | 08:12 AM
Tul01's Avatar
Tul01
The vin is F10AC863832. Thanks
Old Aug 14, 2022 | 09:13 AM
James_Western_Canada's Avatar
Everything you need to know to decode a vin is in link below......but the vin itself will only give you limited info, Series (F100, F250, F350, etc), engine size, Assembly plant, and month it was built. If you had the data plate, more things would be revealed.
https://www.fordification.info/vindecoder.htm
F10 = F100
A= 240 C.I. I-6
C= Ontario Assembly Plant
863832= Produced May/1966
Old Aug 15, 2022 | 07:34 AM
Tul01's Avatar
Tul01
Ok cool at least the year is confirmed. I believe the data plate is gone. The cab he had had nothing on it at all, it was in primer. I will see if he has the tags somewhere. Thanks.
Brent
Trela Wishon
Large Truck
Mar 1, 2021 11:31 PM
Meylan
May 12, 2016 04:26 AM
CrzHelm
Nov 5, 2010 08:44 AM
Ivan M.
Feb 6, 2009 05:20 PM
