Oil pressure problems
Old Aug 13, 2022 | 05:37 PM
tzep's Avatar
tzep
2nd Gear
I have a 2002 Ford F-250 7.3 I was changing the front cover on my Ford F-250 finished all up then I went ahead and got a new low oil pressure pump but all of a sudden the truck is a no start and I have checked the hpop reservoir and it has no oil I can fill it up and the truck will start and stay running but it shows I have no oil pressure unless I’m above 1000 rpm’s once I’m above 1000 rpm’s the oil pressure will go back to normal and the truck will run just fine but once I come to a stop and I sit at idle the oil pressure will go back to nothing and the truck will start running like crap the high oil pressure pump is less than a year old and I’m totally blanked on what it might be
Old Aug 13, 2022 | 08:29 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
After sitting overnight does the oil level in the HPOP reservoir go down?
And welcome to FTE!
Old Aug 13, 2022 | 08:49 PM
tzep's Avatar
tzep
2nd Gear
@aawlberninf350 yes Hpopreservoir will be completely empty if you let it sit over night
Old Aug 14, 2022 | 01:43 AM
aawlberninf350
It's a Van Gogh
Sounds like the oil anti-drainback valve isn't working properly. Noted as Short Circuit Device in the illustration below. Thought I had a pic of it from above but can't find it. IIRC it's a 3/8 square drive plug with a simple ball and spring check valve underneath.
Not sure if that will help the running issue tho.
Old Aug 14, 2022 | 06:18 AM
udsuth78's Avatar
udsuth78
When you installed the new low pressure pump did you soak it in motor oil like described in the instructions? If not the the pump could likely be air locked. No amount of cranking will prime the pump either. If that does turn out to be your problem the only way to get it primed is take it back off or raise the rear of the truck high enough to let the oil reach the pump.
Old Aug 14, 2022 | 06:27 AM
Walleye Hunter's Avatar
Walleye Hunter
And welcome to FTE!
You homed in on that quick enough.
But if he's got the engine running, wouldn't that eliminate that?
Old Aug 14, 2022 | 06:33 AM
udsuth78's Avatar
udsuth78
Not if it only runs long enough to drain the res. Embarrassed to say I learned the hard way on this one. Mongo no need destructions. I screwed with it for like 2 hrs before I threw in the towel and just pulled it off and did it right.
Old Aug 14, 2022 | 08:22 AM
Listor's Avatar
Listor
One thing to learn about these monsters, never rush the process! Any one of us can tell you how rushing to the light in the tunnel lets you miss a crucial step in the process!
I just hope it is fixable , take it apart and start over!
Also looking at the illustration, would you not be able to fill (prime the Lpop) as you assemble?
Jonathan Martin
Oct 8, 2024 07:17 AM
Aidanparm38
Feb 2, 2022 06:13 PM
gbickford
Nov 10, 2004 10:14 PM
55forder
Apr 2, 2002 01:12 PM
