Hey Dave,
FYI,,I have not personally set up a 9" Ford..,,
But,, I thought the ring and pinion were all together as one unit.
Seems like just pull axles out of donor rear pull pumpkin, Check gear ratio clean it up, check out backlash, inspect teeth, look it over and if good stick it in OP truck.
If I am out of line here sorry.
Alex
Buddy helped me just swap the pumpkins. It was easy, sans the oil bath. Can't wait to get this truck restored!
Momma wants black with red flames to match the red interior of the donor truck, with a 3 inch lift. Goin' to have to keep her.
