Power steering problem
Aug 11, 2022 | 06:20 PM
So I just swapped my 99 f250 cab, 6.8, and tranny transfer case onto an 06 f550 chassis. Everything works great but I can seem to get my power steering to work. I have jacked the front up, and turned the steering wheel lock to lock probably over a hundred times. No difference. Any idea what may be the problem? Power steering was great before the swap.
Aug 11, 2022 | 06:33 PM
Also, this power steering pump was turning 37" tires which really makes me think it's not the pump
Aug 12, 2022 | 04:40 PM
Aug 12, 2022 | 11:21 PM
I won't be a ton of help, but maybe it'll spark some conversation.
Are you sure you've got the hoses hooked up correctly? testing the pump for flow wouldn't be bad, though could get messy.
Sorry I don't have more for you.
Aug 12, 2022 | 11:45 PM
"Steering problem 2005 F250 5.4".......Try this forum title. It's got some guys talking about your very same issue....
Aug 13, 2022 | 12:00 AM
Quote:
Originally Posted by
62fordF250
Thought of that too so I got diagrams from both vehicles to check it and it's hooked up correctly.
Aug 16, 2022 | 07:11 PM
So I bought a new power steering pump for an 06 f350 with the 6.0 and it may have helped some but not really. What else could be wrong? None of the steering components are bad because it spins pretty good when lifted up off the ground.
Aug 17, 2022 | 08:23 PM
Any thoughts? It really sucks driving this thing in tight parking lots and out in the pastures
Aug 17, 2022 | 09:37 PM
I once had problem with the return hose collapsing. I found this out after replacing the pump and it was still not working, worth a look
DerekP
Aug 1, 2021 03:20 PM
ibewshooter
2015 - 2020 F150
Apr 22, 2016 07:46 AM
Motoryder714
1983 - 2012 Ranger & B-Series
Dec 21, 2001 12:13 PM
