No crank
Old Aug 9, 2022 | 09:48 PM
chad.parker123's Avatar
chad.parker123
Trailering
No crank
I have a 97 f-250 7.3 zf5.I was at the beach today went to start up my truck and it wouldn’t crank. I checked all my fuses they are fine.if I turn the key to the on position and cross the starter solenoid it started right up. But I don’t have my speedometer or odometer but all other gauges work fine.I have taken off my clutch safety switch a long time ago and crossed the wires so I wouldn’t need it. I’m confused at what could be going on as I’ve checked the fuses that are applicable.
also my abs light is now on when it is on.
Old Aug 16, 2022 | 10:34 AM
knottyrope's Avatar
knottyrope
check those crossed wires, maybe somethinng fell off
i had my key switch fail and do same thing
just have to start going through it to find where it isnt working.
Old Aug 19, 2022 | 07:44 PM
Action4478's Avatar
Action4478
You need a new starter solenoid. for one , do that first . then the speed sensor on the rear axle .
Old Aug 25, 2022 | 11:40 AM
chad.parker123
Trailering
got a new solenoid didn’t fix my cranking problem also got a new ignition switch
Old Aug 25, 2022 | 12:31 PM
knottyrope's Avatar
knottyrope
are you getting power to the solenoid?
Old Aug 25, 2022 | 12:37 PM
chad.parker123
Trailering
We multi metered it and it showed power I have a feeling it’s to do with the clutch safety switch system
Old Aug 25, 2022 | 01:18 PM
ajjw0828's Avatar
ajjw0828
Do you have a electrical schematic for it? If not I might be able to help.
Old Aug 25, 2022 | 01:24 PM
knottyrope's Avatar
knottyrope
if its powered and not switching, is it clicking with the key? If yes maybe the stud lug turned when you tightened it so it cant make proper contact
Old Aug 25, 2022 | 02:53 PM
chad.parker123
Trailering
i do not have a anything like that
Old Aug 25, 2022 | 02:55 PM
chad.parker123
Trailering
i hear some clicking coming from the relay/fuse box but no clicking from the solenoid
Old Aug 26, 2022 | 10:13 AM
knottyrope's Avatar
knottyrope
if you have power to the coil of the relay and it dont click then its either bad or maybe its not self grounding
do you know the part number and provide a pic of it?
HankThaTank
18
Sep 4, 2021 09:49 PM
frustratinglyford
Jan 5, 2019 10:11 AM
skylinetowing
Dec 22, 2018 01:01 PM
lifted77f250
Mar 26, 2011 04:58 PM
crackshot
Mar 5, 2009 11:57 AM
