Offroad & 4x4
What has impressed you?
Old Nov 16, 2003 | 01:58 AM
  #31
Pkupman82's Avatar
Pkupman82
I just ordered an off road kit for my hi lift jack and a steering stabilizer kit for my 84 F150! You guys mentioning home made mods reminds me. I designed and built a roof mounted light bar for the 84 when I was in high school. I built it out of 1 inch box tubing and 1/8 inch steel plate, it turned out really nice. Now I have five 100 watt off road lights and my CB antennas mounted up there.
Old Nov 16, 2003 | 10:51 AM
  #32
85351ho's Avatar
85351ho
i busted my throttle linkage on my 79 last night and had no pedal....made a ne wone out of fire wire for cheap (nothing)
Old Nov 16, 2003 | 04:48 PM
  #33
proeliator's Avatar
proeliator
And the award goes to: Ho!
A throttle linkage made out of firewood...
gotta love those wheeling breaks where you've got to REALLY get creative. Hell, I think thats got all of mine beat...
Old Nov 16, 2003 | 05:17 PM
  #34
JeremyH's Avatar
JeremyH
I've got another that really kicks ***.......a while ago I made a hand throttle out of a bike shifter and rear deraileur cable. Great for those times when you wish you had three feet (stopped and on a steep incline).
Old Nov 16, 2003 | 11:18 PM
  #35
red_rocket's Avatar
red_rocket
Best mod I ever did on the F-150 was a mini-spool in the rearend, about $35 with the hardened cross pin.
Best mod I did on the BroncoII was lincoln lockers front and rear. offroad, it will outdo my F-150 in about everything but mud. Cost? free
the only downside, it has way to much power for the stock axles, and snaps front shafts like twigs.
Old Nov 17, 2003 | 03:39 AM
  #36
Pkupman82's Avatar
Pkupman82
I was thinking of doing that also! Would I also be able to use it as a cruise control? How fast will it go up to?
Old Nov 17, 2003 | 06:36 AM
  #37
JeremyH's Avatar
JeremyH
I use it as a cheap cruise control on the highway, yes. However it is not the same as a contentional cc.......it keeps the throttle at the same position.......not the same speed. How fast it goes depends on how tight you set the cable.
Here is a write-up that I found on another guy's jeep site.......this is pretty much exactly what I did. Make sure to use a non-indexing shifter and a LONG shifter cable.
http://www.stu-offroad.com/jeep_thro...p_throttle.htm
The only difference on mine is that I used a cable clamp to hold my wire to the throttle.
Old Nov 17, 2003 | 09:25 AM
  #38
KJKozak2's Avatar
KJKozak2
I'm with red_rocket. My best O/R performance mod was the mini-spool. Second was removing my 33x12.5x15 Bahas and putting on 35x12.5x15 BFG/MT (also my favorite "I did it myself" mod since all I used was 2 pry bars and a 12v emergency air compressor)
Coolest mod (IMO) was the homemade tilting front clip.
Favorite "rig job" mod was the homemade dual exhaust sustem.
Smartest mod was simply running all axle/dif breathers into the cab.
Kevin K.
Old Nov 17, 2003 | 07:50 PM
  #39
teds74ford's Avatar
teds74ford
Hey, just wanted to say I put the pics of the hitch in my gallery. I built it to slide in my framerails, keeping it as high as possible, as well as subtle. The side plates are 1/4" plate that the cross tube sits inside. Enjoy! Ted
Old Nov 18, 2003 | 02:46 AM
  #40
Pkupman82's Avatar
Pkupman82
That is exactly what I was thinking! So you can run 70+ mph with that? I have a 1000 mile road trip ahead of me next month, I would like to have cruise control. I think it would also be nice for keeping the truck running if it decides to get stubborn on cold mornings.
Old Nov 18, 2003 | 07:15 AM
  #41
JeremyH's Avatar
JeremyH
Yep......it'll work for that.
Old Nov 19, 2003 | 03:28 AM
  #42
Pkupman82's Avatar
Pkupman82
Thumbs up
Awesome...one more project to add to my "to do list"!
Old Nov 19, 2003 | 10:17 AM
  #43
fishmanndotcom's Avatar
fishmanndotcom
no one has said anything about it so i will....all i need to say ZF-6 speed
also the welded front and rear
-jason-
Old Nov 19, 2003 | 10:35 AM
  #44
mattsf250's Avatar
mattsf250
borgeson steering shaft.
i know, it was maintenance, but OMG what a difference!
i know do not worry about my steering at all, i used to worry when potholes approached (~1/2 turn of play in wheel)
second fave... mfg mud t/a's
third (or is it first fave?) tack welding the bearing cups to the axles! ah, no mo thrown cups! (new axles, and u joints, still threw three cups?) that one has saved me a ton of time.
Old Nov 19, 2003 | 12:19 PM
  #45
Texan1983's Avatar
Texan1983
i just put a borgeson steering shaft in my truck too. you are right what a differnce.
