Proven tuned questions
Old Aug 9, 2022 | 01:57 PM
Bair1218's Avatar
Bair1218
I've got a 2018 6.7 and after towing my camper about 300 miles I'm getting black smoke on take off and when passing on the highway. I have a proven tow tune at 50hp. It was 100% clean before I towed and now I get small bursts of black smoke.
I've done new fuel filters, cleaned the air filter, and new H&S cold side pipe which was more preventative than anything.
Does anyone have any suggestions? I'm in Maryland so elevation shouldn't be a concern I don't believe. Also for 8k miles or so the tune was all clean until the last 500 miles or so since towing.
Old Aug 9, 2022 | 02:36 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Have you asked at wherever you got the tune from?
Have you tried tuning back to stock and see what it does then?
Old Aug 9, 2022 | 02:46 PM
Bair1218's Avatar
Bair1218
Can't go back to stock... and yes that's how I ended up with new fuel filters and the other items I've messed with
Old Aug 9, 2022 | 02:47 PM
chief1232's Avatar
chief1232
Do you have SOTF? Any chance you bumped it up to a higher tune without noticing?
Old Aug 9, 2022 | 02:59 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Why can't you go back to stock?
Did you delete it as well as tune?
Old Aug 9, 2022 | 03:13 PM
Bair1218's Avatar
Bair1218
Deleted and just a single tune. No SOTF
Old Aug 9, 2022 | 08:53 PM
UGA33's Avatar
UGA33
Do you have a way to monitor VGT function? May be sticking or the solenoid is slow to respond. Also, pull the MAP sensor and clean it real good.
Old Aug 10, 2022 | 12:44 AM
Blazn's Avatar
Blazn
If you go to Proven's website you can create a support ticket with your issue, Do some data logging with your tuner and send it to Proven so they can see if they notice anything abnormal.
Old Aug 10, 2022 | 11:57 AM
speakerfritz's Avatar
speakerfritz
check your map sensor. clean it or replace if needed.
Old Aug 10, 2022 | 12:24 PM
acadianbob's Avatar
acadianbob
I would guess that your tune is dumping more fuel into the engine than it can burn under the circumstances.
Old Aug 11, 2022 | 06:45 AM
cosburn2005's Avatar
cosburn2005
50hp tune from Proven doesnt smoke unless you stab the throttle. Even then its not much. I have put dozens of them on 6.7 trucks.
I would look towards something mechanical like the MAP sensor or boost leak.
Old Aug 11, 2022 | 07:51 AM
deveroutdoors's Avatar
deveroutdoors
Proven has a few versions of their OEM tune minus emissions. For example, one for Hiss and one for Rumble exhaust sound. There are other 0HP, No Em tunes available via EZ Lynk if you have one. You might try going to one of those or another 50HP tune and see if it clears up. I've been running one of their 0HP tunes for quite a while and have never had smoke.
Old Aug 22, 2022 | 11:34 AM
Bair1218's Avatar
Bair1218
Ok, so I tried cleaning the map sensor and I ruined it so I replaced that. The tune was extremely clean prior to me towing the camper and now I'm getting the smoke. So idk if it's necessarily the tune itself but I guess it could be. I have 8k miles or so on the tune and literally just started smoking the last 1k miles. The truck has 39k on it.
Old Aug 22, 2022 | 11:35 AM
Bair1218's Avatar
Bair1218
I have the 50hp tune but I use the sct to tune it so I don't see all the other tunes I'm guessing. They said the one I got was a 50hp tow tune
Old Aug 22, 2022 | 11:43 AM
mattymax's Avatar
mattymax
Does the 50hp from proven come with a trans tune ? I have 0hp from proven now
