Coolant checker
Old Aug 8, 2022 | 07:12 PM
acdii's Avatar
acdii
Coolant checker
When I had my 99 I had test strips and additives, with the 2012 I didn't really pay it much attention since I didn't drive it much, only on trips. I am now getting a 2019 F-450 for my tow vehicle and daily driver, and since it is in excellent condition, I want it to stay that way, so what do I use to check the coolant, and are there additives like on the 99? This stuff has changed so much since then.
Note, Not an oil thread! LOL I am well versed on THAT subject!
Old Aug 8, 2022 | 07:56 PM
mptjelgin's Avatar
mptjelgin
The coolants used in the 2019 and later trucks no longer require any type of testing. This may have started earlier, but I have a 2019 and I know for certain that coolant testing is not required. Likewise no need to worry about additive packages.
Old Aug 9, 2022 | 04:41 PM
acdii's Avatar
acdii
Thats what I thought, but wasn't 100% sure. There are test strips for the 2012 coolant, but haven't bothered to check for what years.
Old Aug 9, 2022 | 07:15 PM
senix's Avatar
senix
nothing with the newer coolant. Drive it and change it according to the manual.
Old Aug 10, 2022 | 03:09 PM
Dirthawg2.0's Avatar
Dirthawg2.0
F-250 - F-550 with build dates from 2011 up to July 8, 2018 had orange coolant that required testing.
F-250 - F-550 with build dates of July 9, 2018 and up use yellow coolant that does not require testing.
Ford has discontinued the orange coolant, some older trucks could have been switched over to the newer yellow coolant. I had mine flushed and filled with yellow the last time it was at the dealer.
Old Aug 12, 2022 | 10:42 PM
acdii's Avatar
acdii
OK, I got my new to me 19 and sure enough, manual says no testing required. Thats cool, one less thing t worry about.
Old Aug 13, 2022 | 06:07 AM
senix's Avatar
senix
But....be sure to check the levels though!
Old Aug 13, 2022 | 10:52 AM
acdii's Avatar
acdii
Oh yeah, first thing I did before even getting in ans starting it the first time. Both tanks!
Old Aug 13, 2022 | 04:14 PM
FishOnOne's Avatar
FishOnOne
I would inspect the color of the coolant as well. If it's not a pure yellow color, I would have it changed. Sometimes the quick lube stores will top off the coolant if its low and you have to wonder if they're topping off with the correct compatible coolant type.
runningman777
Aug 25, 2021 02:23 AM
Kurt32
Dec 10, 2014 01:53 PM
koski19
Feb 16, 2013 07:07 PM
60RatRod
16
May 5, 2009 01:49 PM
qman
Mar 6, 2006 12:36 PM
