rad level
Old Nov 10, 2003 | 06:52 PM
351 power's Avatar
351 power
rad level
My rad stays down about five inches from the top no matter how many times I fill it. It seems to either leak by the cap and down the side of the rad, or out around the thermostat housing. The thermostat is new with the gasket. The cap is a 13 lb. and is old. Once it reaches this level it stops leaking but it is just barely at the top rad hose. Is the cap faulty? It is the OEM required lbs. (88 150 351w). The temp. is staying at its normal spot.
Old Nov 10, 2003 | 07:35 PM
MunsterGarage's Avatar
MunsterGarage
I would replace the cap if its old...only a few bucks. If its leaking at the housing, seems it would be noticible, and your level would probably keep dropping farther than it does. I would also check that top hose(seeing the level stays about there) it may be rotted and coolant seeping out. If this all fails, then you probably have a leak somewhere around the top of your radiator.........later
Old Nov 11, 2003 | 06:19 AM
351 power's Avatar
351 power
Thanks. I like "Ugly trucks Rule", they have character.
MFJ
29
Sep 8, 2014 12:46 AM
Matty Fraser
Mar 30, 2013 10:58 AM
skeneguy
26
Mar 28, 2012 06:24 PM
gwm
Aerostar
24
Jul 12, 2008 02:55 AM
rpokorny
Aerostar
Jul 7, 2004 12:02 PM
