I am in the process of installing a Gibson performance exhaust system on my 1987 Class C motorhome (built on a E350 RV cutaway chassis - 460CID carbureated engine - C6 Auto trans). Just installed the left side left header and it is interfering with the transmission shift rod. The shift rod has a bend in it- and it is hitting up against the header pipes.
Has anyone installed headers on an E series - and if so - did you run into same problem?? I'm thinking that the only solution is to modify existing shift rod (cut/bend/weld) - or fabricate a new one that will be able to clear the header pipes.
