Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Electrical Fan questions
Old Aug 3, 2022 | 12:58 PM
2020FordRaptor's Avatar
2020FordRaptor
Hello everyone:
Even though I don't own a Lightning, I do own a 2003 Fx4 and I though I would get better answers for my question here than on other forums. Have anyone had any experience with Flex-A-Lite 270 Dual Electric Fans or TSP HC7106 Pro Series Dual 11" Fans? The Flex-A-Lite is almost 4 times more expensive ($493 vs $145) but it's CFM rating is 5,500 compared to the TSP at 2,780. Also, the TSP draws 25 AMPs from the system while the Flex-A-Lite draws 28 AMPs. Will the extra AMPs matter? Will I need the extra CFM rating that the Flex-A-Lite provides? How are both in terms of quality? Both have a one year warranty. My final question is, are there any better options?
Thanks!
2003 FORD F 150 Flex-a-lite 270 Flex-A-Lite Direct Fit Dual Electric Fans | Summit Racing
TSP® - Pro Series Dual 11" Cooling Fan
Old Aug 5, 2022 | 03:57 PM
Blurry94's Avatar
Blurry94
Important part is that if the TSP fan shroud covers the radiator and if the if 2750cfm will be sufficient in the heat of the summer, when you're stopped at light and the AC wide open. Another factor is making sure they run when the AC clutch is engaged. If it can keep the temps in check, under those conditions, then you should be good.
I'm a little partial towards the flex a lite models because I have a 295 series on my 94; 13.5" dual puller fans with a VSC. It covers the entire radiator, works with my AC, has a soft start and two speeds. I've had zero cooling issues with this setup and it's been on my truck for 15+ years.
Old Aug 8, 2022 | 12:39 PM
Beechkid's Avatar
Beechkid
Stick with OEM replacement units!
I had to replace the e-fan on my wife's 97 Cougar Sport 10 years ago...the complete assembly including the faring was $129 IIRR Yeah, probably a bit more now but it works!
Old Aug 8, 2022 | 12:40 PM
2020FordRaptor
Originally Posted by Beechkid
Stick with OEM!
I would usually agree but I thought if I could free up some ponies I would be happy.
Old Aug 8, 2022 | 04:56 PM
Beechkid's Avatar
Beechkid
I meant stick with OE spec replacement e-fans
Old Aug 8, 2022 | 04:59 PM
2020FordRaptor
Oh okay. Yah I might do that.
Old Aug 9, 2022 | 11:50 AM
STOFFERJ's Avatar
STOFFERJ
“raptor efan” for the win
2020FordRaptor
Aftermarket Products
Mar 16, 2023 10:49 PM
2020FordRaptor
Aug 6, 2022 11:24 AM
2020FordRaptor
1997 - 2003 F150
Aug 4, 2022 04:43 PM
jaygee15
18
Mar 19, 2019 04:44 PM
gumboluvr
Jul 17, 2006 12:49 PM
