I tested the spout when it's plugged in no spark when it's unplugged I get spark. Still have a pump issue but I can't hear any of the 3 relays make a click under the hood any ideas thank you for the help
You have the symptoms of a bad PCM computer. Remove it and check the capacitors for leaking.
Oh boy the PCM is the main computer right? If so can I get some photos of where this is located please how would one go about checking it for leakage? Any idea what causes a PCM to leak? Thanks for the help
I would lean toward 30 yr old PCM, got any pics of it, ever been wet, in floor board, some leaked water out of the cowl.
Oh, I've got just two until I can pull it tomorrow, far as I know it's never been wet that being said I do live on a dirt road in western Montana, not that I noticed.
