Engine governor module
Old Aug 2, 2022 | 07:51 PM
Zacbkennedy's Avatar
Zacbkennedy
I was digging through the dash trying to figure out why the wipers weren’t working and came across this module part number
that looks completely roast can anyone tell me what this is and what this does.
Old Aug 2, 2022 | 09:13 PM
Hit Man X's Avatar
Hit Man X
What year, engine, trans?
EECIV has rev limiter built into it.
Old Aug 3, 2022 | 06:18 AM
Zacbkennedy
Its a 1995 f700 with a 429 7.0 with an automatic transmission
Old Aug 3, 2022 | 07:50 AM
R&RFord's Avatar
R&RFord
Looks like a speed governor.
Also looks like water damage. Your wiper module may have met a similar fate.
Old Aug 3, 2022 | 08:29 AM
Zacbkennedy
if this went bad could it cause the engine to seem likes its dying at random times? working on issue where when it gets to 3/4 of a tank it starts acting like its out of gas. any relation you think?
Old Aug 3, 2022 | 09:38 AM
Zacbkennedy
where would the wiper module be?
Old Aug 3, 2022 | 12:14 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Ah, then I am incorrect. I assumed it was for the 150-350 trucks.
Have you checked for voltage at the wiper motor itself or jumped it? I would start with an EVTM.
Old Aug 3, 2022 | 01:56 PM
Prototypemech's Avatar
Prototypemech
I haven't dug behind the dash on ford medium duty trucks, but it's common for medium duty trucks to have an idle-up feature to boost up the rpm to 1500-2000 to spin up PTOs and hydraulic pumps faster. Do you have a switch on your dash that does nothing? It might be your idle-up switch. On early 90's GMC medium duty trucks, their throttle bodies are kind of unique. The throttle cable goes to the throttle body, where it turns a potentiometer, that commands a servo to open the throttle. It simplifies the idle-up linkage, since it's just a digital signal at that point. I'm guessing ford does a similar thing, which might explain your throttle issues. Take a picture of your throttle body and post it here.
Old Aug 3, 2022 | 04:10 PM
Scndsin's Avatar
Scndsin
Here's a "BB" on e-bay:
https://www.ebay.com/itm/184847367398
frysl
Jun 15, 2022 10:37 AM
manicmechanic007
Oct 9, 2021 12:47 AM
rsmyre
19
Oct 24, 2018 08:13 AM
EDsurvivor
Aug 14, 2012 01:18 PM
bebeard
Jun 22, 2011 08:14 PM
