351 windsor swap
Old Aug 2, 2022 | 06:13 PM
Pdesgens's Avatar
Pdesgens
4wd Low
351 windsor swap
Hi fellow Ford Enthusiasts. My 79 4X4 F150 engine sadly just died yesterday (351 windsor). Are there any Ford crate engines available with efi? Or can the core be sent out and replaced by a rebuilt 351 with a bit more power? Also looking to upgrade from the 4 speed manual transmission for a 5 speed…any suggestions?
thanks in advance!
Old Aug 2, 2022 | 07:47 PM
Conanski's Avatar
Conanski
Nice looking truck.
You can order or build a 351w to any power level you want, you just need the appropriate amount of cash.
For transmissions, Ford made the M5OD, ZF5 and 6 speeds and the T5 found in mustangs, the ZF is a HD truck trans with granny 1st while the others are more street oriented, all can work with a windsor.
Old Aug 2, 2022 | 09:05 PM
Pdesgens's Avatar
Pdesgens
4wd Low
Recommended dealers
Thanks for your reply Conanski!
any idea where I can buy engine and transmission mentionned in your comment?
thanks
Old Aug 3, 2022 | 08:32 AM
Sancho's Avatar
Sancho
You might make sure it's a Windsor. I had one like that, and it was a 351m.
Old Aug 7, 2022 | 12:46 PM
tbear853's Avatar
tbear853
A '79 4x4 with a 351W?
Valve cover bolt quantities vs Ford engine families:
2 bolts: "Y" Blocks
239/256/272/292/312 (produced from 1954 to 1964)
5 bolts: FE Series
332/352/360/361/390/391/406/410/427/428
6 bolts: SBF group
221/260/289/302/351W
7 bolts: 385 Series
429/460
8 bolts: 335 Series
351C/351M/400
grage101
Feb 28, 2009 02:31 PM
Dirigo
Jul 23, 2007 10:06 PM
rusty350250
Jan 9, 2007 12:24 PM
david00f150
Aug 27, 2006 06:00 PM
