91 idles fast
Old Oct 12, 1999 | 06:38 PM
jon_1's Avatar
jon_1
91 idles fast
my 91 f150 (5.0)wants to idle around 1200rpm and doesnt want to come back down to idle after accelerating to shift (it takes about 2 to 3 sec)I replaced the throttle position sensor and this did not help. any suggestions? thanks
Old Oct 13, 1999 | 08:17 AM
Phillip Guidry's Avatar
Phillip Guidry
91 idles fast
First you will want to push on the lever at the throttle body to verify the linkage/cable isn't in a bind.Secondly,you may have a vacuum leak.verify all vacuum lines and re-tighten the intake manifold{s}.I have also noticed that a faulty CTS{coolant temp sensor,not sender}will make an engine idle fast even after a sufficient warm-up,if the thermostat is at least a 180~.Lastly,swab the throttle bores blean with a nylon barrel brush dipped in solvent while holding the flap{s} wide open.No need to get deep in there,just in the area that the flap{s} are.Good luck.
Phillip
Old Oct 15, 1999 | 07:20 AM
Phillip Guidry
91 idles fast
Obs91
Feb 8, 2016 05:08 PM
91Fbody
Apr 30, 2015 10:26 AM
midmofarmer
Apr 11, 2015 06:09 PM
EFM
32
Mar 10, 2008 08:40 PM
whaleral
Jan 11, 2004 02:48 AM
