Deck Height Different Tween 3.8/4.2?
Old Jul 31, 2022 | 07:34 PM
Scndsin's Avatar
Scndsin
Is the block identical on both 3.8 & 4.2, or is the 4.2 taller?
Just did a ring/bearing rebuild on an aging 98 Mustang's 3.8 & wondered if we missed an opportunity to use a 4.2 short block for a little more umph.
I've got a Triumph GT-6 that I'm kicking around the idea of a V6/T-5 swap & my local yard has plenty donor material trucks & sn-95s & 197s
Old Jul 31, 2022 | 10:26 PM
Johnny Paycheck's Avatar
Johnny Paycheck
I believe everything is the same but the crank between these two engines.
A 4.2 block itself won’t add anything.
If memory serves correct, 3.8 Mustang guys swap the 4.2 crank and go to town.
Old Aug 1, 2022 | 07:41 AM
Scndsin's Avatar
Scndsin
Thank you much. Just wondered if a 3.8 lower manifold would span the valley of a 4.2 short block if fitted with 3.8 heads.
Those FE looking, split 4.2 heads look tiny, besides the weight.
Boundsf150
1997 - 2003 F150
Aug 28, 2007 11:58 AM
f100guy
3.8 & 4.2L V6
Jan 14, 2004 06:30 PM
mantta
3.8 & 4.2L V6
Apr 30, 2003 10:12 AM
