Wiper switch/control test procedure?
Old Jul 31, 2022 | 05:49 PM
Revnate's Avatar
Revnate
1988 F-150
Background: bought the truck non-running earlier this year after it had sat for 15 years. The wipers only ran when the switch was in the high-speed position. Yesterday they stopped working altogether.
I had suspected a bad wiper control module, because the symptoms seemed consistent. Pulled the module this afternoon and found one broken connection. Resoldered it and reinstalled. I have wipers again, but still only with the switch on high-speed.
So I may have missed something in the control module, but now I’m really wondering about the condition of the switch itself and would like to test it. If anyone could guide me through testing the wiper switch, I’d be very much appreciative.
Thanks.
Old Aug 1, 2022 | 11:40 AM
rla2005's Avatar
rla2005
Here you go....
Old Aug 1, 2022 | 01:08 PM
Revnate's Avatar
Revnate
Originally Posted by rla2005
Here you go....
Thanks much! That’s exactly what I needed.
Any chance you might have a similar diagnostic guide for the control module itself? Just in case the switch checks out, I have to go back to square 1 with it.
Old Aug 1, 2022 | 02:04 PM
rla2005's Avatar
rla2005
Try this...
Old Aug 1, 2022 | 05:11 PM
Revnate's Avatar
Revnate
Try this...
thanks again!
Old Aug 17, 2022 | 01:42 PM
dremtofford's Avatar
dremtofford
that looks like the same switch as my 69 f250
Old Aug 17, 2022 | 02:14 PM
yardbird's Avatar
yardbird
The control modules are probe to bad solder joints, primarily from the e-brake slamming against the stop on the dash when releasing the brake.
I had to re-solder mine three times until I finally wrapped the control unit in foam and laid it on top of the wires instead of mounting it. No problem for over 20 years now.
Go over all the solder joints with a fine point soldering iron. That may fix your problem.
Old Sep 19, 2022 | 03:03 PM
Revnate's Avatar
Revnate
I’m back….
wiper switch and relay box were both bad, which makes sense in hindsight. The truck sat for 15 years and things tend to corrode when not in use. I replaced both the wiper switch and relay box with new parts and the wipers functioned correctly, at least for a while.
Now my wipers once again will only work with the switch turned to high speed- except they don’t run like they normally would on high speed. There is a very short delay, as if they were set to delay.
I’m at a loss at this point.
ideas?
Old Sep 19, 2022 | 03:16 PM
rla2005's Avatar
rla2005
New parts does not mean good parts. Go back and retest everything.
Post# 4
Old Oct 4, 2022 | 01:37 PM
Revnate's Avatar
Revnate
I am just updating for the sake of future reference. I always come across threads where someone has dealt with a problem similar to one I might be dealing with, but often times the thread just fades away with no resolution.
Rla2005 hit the nail on the head. My new control module was the problem. The wire terminal ends on the plug going into the wiper switch were not installed correctly in manufacturing and some of them had worked loose. Two of the wires were completely disconnected.
Dennis Carpenter (where I bought the new module) was no help. I ended up repairing it myself, which wasn’t a big deal. But I made a mental note in my list of companies that do not stand behind the products they sell.
Anyway, I have wipers again. Not that I need them in this drought, but they’ll be ready when the rain comes.
Old Oct 4, 2022 | 02:29 PM
rla2005's Avatar
rla2005
Glad you got it figured out. Thanks for the update!
KiwiFord
16
Apr 8, 2011 05:44 PM
LoneStarTrucker
13
Jun 30, 2008 08:41 PM
cpettymore7777
Aug 6, 2004 03:20 AM
John Pen
1978 - 1996 Big Bronco
Dec 19, 2003 12:50 PM
