Carb leak
Old Jul 31, 2022 | 04:33 PM
markwinans's Avatar
markwinans
Trailering
Carb leak
Went to start my '74 Normal cold start Pull the choke three stomps Hold the throttle open and it starts right off However acted like I didn't close the choke after start and it died. Upon inspection had lots of fuel on top of engine After drying out had my son observe as I went through my same routine This is what he saw Let me know your thoughts
File Type: mov
Old Aug 1, 2022 | 08:51 AM
ranger140892's Avatar
ranger140892
Grumpy goat
That's the float bowl vent. I don't know those Motocraft carbs very well, but if one of my Holley's or Edelbrocks did that, I'd say a needle & seat is probably bad.
Old Aug 1, 2022 | 12:20 PM
markwinans's Avatar
markwinans
Trailering
It is actually a Holley so I'll start there
Old Aug 1, 2022 | 07:15 PM
5851a's Avatar
5851a
Couple taps with screwdriver handle over needle might get it unstuck sometimes. Don't use a hammer.
Old Aug 1, 2022 | 09:14 PM
Rubiranch's Avatar
Rubiranch
I'd pull the needle and seat and clean it or replace it.
That's a fire waiting to happen.
Old Aug 5, 2022 | 11:33 AM
markwinans's Avatar
markwinans
Trailering
Thanks guys Replaced needle and seats No more leak and runs good but not real sure I got them set exactly correct Any tips for that?
Old Aug 5, 2022 | 01:43 PM
Rubiranch's Avatar
Rubiranch
There should be a plug on the side of the float bowl.
Remove it and adjust the float level to where you have to bump the truck a little to get the fuel to slosh out of the hole.
Old Aug 5, 2022 | 02:36 PM
DB429SCJ's Avatar
DB429SCJ
Is that a model 4011? if it is;https://documents.holley.com/199r9796_scan.pdf
jake_whitman
Jan 16, 2015 01:52 PM
72Truckin
24
Apr 15, 2013 04:41 PM
snipa
Aug 28, 2010 01:25 AM
Hmann
Mar 6, 2010 08:22 AM
boo-yaa138
13
Apr 8, 2007 01:18 AM
