8BA Radiator Hoses
Old Jul 31, 2022 | 03:33 PM
CJMOStang's Avatar
CJMOStang
8BA Radiator Hoses
Does anyone have a stock number of a name brand upper and lower radiator hose that I can ask for at the local parts store for a 49 F1 8BA? I’ve got a fresh rebuild and I’m dying to start it. I’ve searched the internet and I’m dying to start and run it
Old Jul 31, 2022 | 04:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Do you have the steel tubes? or are you looking for single-piece hoses?
If using the steel tubes, NAPA sells 1-1/4" ID hose (for the uppers) and 1-3/4" (lowers) by the foot. The lowers are each 7-1/2" long so you need 2 ft. Probably the same for uppers (4 pieces).
Old Jul 31, 2022 | 06:50 PM
CJMOStang's Avatar
CJMOStang
I don’t have the upper tubes but a flexible hose with no pipes would need to be 25-30”
Old Jul 31, 2022 | 07:39 PM
52 Merc's Avatar
52 Merc
Here's your steel tubes. It shouldn't take long to get a pair.
https://www.npdlink.com/product/pipe...d/135554/50367
And like Ross said, after that, it's just buying a couple lengths of bulk straight hose to connect everything together. Upper and lower are different diameters.
Upper hose, cut into 4 pieces, 2@ 2 1/2" long, 2@ 4 1/4" long
https://www.npdlink.com/product/hose...r/135565/50367
Lower hose, cut into 2 pieces 71/2" long.
https://www.npdlink.com/product/hose...r/135566/50367
I'm sure you can find bulk hose cheaper locally, though.
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Old Aug 1, 2022 | 05:09 PM
mtflat's Avatar
mtflat
I usually buy the green stripe Gates hose at NAPA.
kythri
Nov 29, 2021 06:02 PM
FDV838
Oct 19, 2021 11:55 AM
fourbrrl
Jun 22, 2007 06:26 AM
propane32
Jun 13, 2007 05:42 PM
Gatsby
Jan 21, 2005 02:37 PM
