thermactor smog pump delete
Old Jul 30, 2022 | 03:25 PM
mustangrich's Avatar
mustangrich
4th Gear
Talking thermactor smog pump delete
I have a 1994 F-150 4x4 extended cab with the 351 windsor with 154,000 miles on it. It is in beautiful condition, but the bottom end of the motor is getting loose and noisy (of coarse) and i am planning on doing a short block. I have a 1996 donor truck with all same parts (block for core) but would like to use heads for a smog pump delete. Can anyone give my info on what direction of action I need to take in doing a smog pump delete? I know the heads on the 96' are not roller (H code just like mine) and are already plugged in the back. I will be putting a set of "shorty" headers on this too. I know the 96' is mass air flow, but I just don't have the time to change out the harness, plus i don't know if the donor truck even ran. Thanks for all of your guys input!
chappys4life
Oct 9, 2023 09:15 PM
CrazyFordMan
49
May 22, 2014 04:16 PM
86caprirs
Jan 22, 2008 09:36 PM
fordnut74
1978 - 1996 Big Bronco
Feb 25, 2004 08:53 PM
