Just.
Curious.
Being that you're suggesting it seems like its running stock.
What chipset are you using?
Did you install the chip?
Did you clean the lacquer off the terminals before installing?
Hydra chip with Jelly tunes (same as is on my other truck that work fine)
I have triple checked the chip install as well as had someone check behind me, this problem has been there even before chip install.
I know chip is working because high idle works and other tunes change how it drives but still no boost.
