Re-Ring Job?
Old Nov 10, 2003 | 03:27 PM
kysard's Avatar
kysard
Re-Ring Job?
I had to pull the heads and have a valve job done on my 351, it has about 75,000. I am replacing the timing chain and oil pump while I have the engine apart.
Would it make since to do a ring job? The cylinders are in good shape (I checked taper), but I notived a little oil in one cylinder. I don't want to pull the motor, was thinking of pulling the pistons and re-ringing?
Old Nov 10, 2003 | 03:43 PM
carbo96's Avatar
carbo96
Would the oil in the cylinder be coming from a leaking valve seal in the head? If so, it might save you from doing a ring job if it isn't needed.
Old Nov 10, 2003 | 04:25 PM
kysard's Avatar
kysard
possible, I just want to do everything I can while the motor is apart. I have all winter to work on it, but before I pull the pistons wanted some opinions.
Old Nov 10, 2003 | 07:40 PM
larry derouin's Avatar
larry derouin
If the taper is within specs and the cylinder diameter is fairly constant, I'd leave it alone. With only 75,000 miles on the engine the rings are broke in but way far from needing replacement.
Wipe down the cylinders with some 30w oil and stuff CLEAN rags in the cylinders to keep the dirt out. Wire brush the top of the block and the lifter valley. Take a dremel with a grinding wheel and clean up all the drain holes (casting flash and other crud) in the lifter valley, block, and heads, and flush with diesel oil and then a couple of quarts of 30W. Reassemble the engine(paint what you can while it's apart), and finish painting it.
Fire it up and you've got an engine that will last another 100,000+ miles.
Larry
flipklos
Jul 18, 2012 01:08 AM
1977ford250
Jan 13, 2010 07:39 PM
ranger7570
Oct 25, 2007 11:32 AM
bhaggerton
1983 - 2012 Ranger & B-Series
Mar 21, 2005 09:15 PM
kwing
Feb 3, 2005 08:26 PM
