Activate electric surge brake switch in reverse
Old Jul 22, 2022 | 12:02 PM
Bsikes81's Avatar
Bsikes81
Hey, got a 93 F350 with what looks like a factory 7 round pin plug adapter on the truck. What pin has to have power to activate the electric surge brake valve on a boat trailer? This I the valve that opens up so you can back up the trailer with applying the surge trailer brakes. Also needing to find an adapter to go from this round pin plug to a flat blade tv type plug. Thanks
Old Jul 26, 2022 | 12:30 PM
helifixer's Avatar
helifixer
Use the backup lights pin,
center pin if wired correctly.
Most parts stors have all the different adapters
Old Jul 26, 2022 | 06:58 PM
strokerac's Avatar
strokerac
etrailer if you want to order
Old Jul 26, 2022 | 09:13 PM
Bsikes81's Avatar
Bsikes81
I did test light that while in reverse but didn’t get anything. Is it just wired to the reverse light wiring? Thanks
Old Jul 27, 2022 | 05:34 AM
strokerac's Avatar
strokerac
Yes or should be
You can google 7 pin wiring diagram
Old Sep 6, 2022 | 07:30 PM
NeverboughtanFseries's Avatar
Power to the back up light circuit activates a solenoid that interrupts or blocks the brake fluid hydraulic circuit. They work well when they are wired up correctly.
You will need a flat five pin connector to round 7 pin adapter.
Jason1228
All Things Towing
Feb 27, 2017 02:24 PM
Dlebl1
All Things Towing
Aug 5, 2013 04:33 PM
wildstang
Jun 26, 2012 09:47 AM
nitro3421
32
Apr 9, 2012 09:45 PM
AnOldDog
All Things Towing
Apr 14, 2007 04:04 PM
