Sponsored by: Auxito
obd 2 code PO136
Old Nov 10, 2003 | 12:58 PM
blr's Avatar
blr
Question obd 2 code PO136
Has anyone had any experience with this code. It states"O2 sensor circuit malfunction(Bank 1 Sensor 2).
1998 F150 4.6L
I would like to know the diagnostic procedure for troubleshooting and repair.
Old Nov 10, 2003 | 05:51 PM
LxMan1's Avatar
LxMan1
Hi and welcome to FTE
It is the passenger side sensor that is after the cat. converter. It is usually a sign that the cat. is failing.
I would reset the computer and see if it comes back on.
Jimmy
Old Nov 11, 2003 | 11:31 AM
blr's Avatar
blr
Question
Jimmy, I have reset the computer before and the code re-appears after about a day or two. How do I isolate if this is a failing catalytic converter??
Thanks
Brian
Old Nov 11, 2003 | 06:32 PM
LxMan1's Avatar
LxMan1
That can be difficult if it isn't rattling and falling apart internally.
You could try taking it to a shop that has an exhaust gas anylizer and have them check the exhaust output to see if it is above specs. If not, then I would try switching the two rear O2 sensons from side to side and see if the trouble code changes to bank 2. If so, then I would replace the bad O2 sensor.
Jimmy
Old Nov 12, 2003 | 08:51 AM
blr's Avatar
blr
thanks, I will try that and keep you posted
Brian
Old Nov 19, 2003 | 02:25 PM
blr's Avatar
blr
lxman1, I switched the O2 sensors from one side to the other and it did indeed spit out the code for the opposite bank. Replaced the sensor and problem solved.
Thanks for all your help
Brian
nitrored
1997 - 2003 F150
Oct 3, 2016 05:03 PM
mizzourover
2009 - 2014 F150
Apr 14, 2015 09:28 AM
thunderbird1986
Oct 21, 2013 07:30 AM
rgreen01
Jan 3, 2005 12:25 PM
chevyjr73
Modular V8 (4.6L, 5.4L)
Dec 31, 2004 11:21 AM
