Brake fluid
Old Jul 15, 2022 | 03:21 PM
Vinford's Avatar
Vinford
Brake fluid
77 3/4 ton 2wdr.
brakes are grabbing and also losing pressure?
All wet around master cylinder lid?
what happens when master cylinders goes?
Old Jul 15, 2022 | 04:10 PM
scottscott's Avatar
scottscott
In my experience, when the master cylinder goes bad, the brake pedal goes to the floor, with no braking effect. Usually this happens at the worst possible time.
It's time for you to pull the rear drums, & look for leaking wheel cylinders & worn shoes..
Pull the front wheels & look for leaking calipers, worn brake pads. I'm guessing you have front disc brakes.
Inspect all the brake hoses & steel lines. Look for wet spots & rust.
Wet around the lid could be rust forming on the upper surface where the lid seals. Check the brake fluid level in the master.
Old Jul 15, 2022 | 04:15 PM
4x4 Bart's Avatar
4x4 Bart
Most of the time the pedal will slowly (or quickly) go to the floor as fluid seeps past seal.
Old Jul 15, 2022 | 04:19 PM
4x4 Bart's Avatar
4x4 Bart
Wet around the lid means the rubber cap seal is not sealing to the master cylinder body. Usually due to corrosion on the surface.
Old Jul 15, 2022 | 10:24 PM
Vinford's Avatar
Vinford
Put new calipers on the front and removed drums on back 50% brakes on back.
Only wet seems to be around the rez tank?
could it suck air through the lid, and if it did would it matter?
Old Jul 16, 2022 | 11:28 PM
tbear853's Avatar
tbear853
No, it won't suck air through a leaking master cylinder cap gasket, just make a mess.
Check your rubber hoses for wetness, cracks, and even the steel lines which can rust in time.
Old Jul 17, 2022 | 08:31 AM
440 sixpack's Avatar
440 sixpack
Grabbing on the front or back ?
Losing pressure meaning the brakes fade? or the pedal keeps going down ?
Old Jul 19, 2022 | 12:42 AM
Vinford's Avatar
Vinford
Pedal keeps going down
Old Jul 19, 2022 | 08:25 AM
440 sixpack
That can be caused by a failing master . it shouldn't cause grabbing though, that could be an unrelated problem.
If you're not leaking anywhere and bleeding the system doesn't help I'd start by checking the booster then replacing the master. it's cheap and easy to do .
Old Jul 21, 2022 | 10:19 AM
tbear853's Avatar
tbear853
Leaking axle seal letting axle lube leak in a drum brake will cause sudden grabbing as brake shoes get contaminated.
Lubbockguy1979
Mar 11, 2022 08:32 PM
dentside79
Apr 6, 2009 05:46 PM
sedly
Dec 23, 2007 07:46 PM
Aarkie
Sep 3, 2003 10:17 PM
wa68ranger
Jan 9, 2002 02:48 PM
