Sponsored by: Real Truck
F250 Super Duty Body Mounts
Old Jul 15, 2022 | 12:02 AM
ramon1943's Avatar
ramon1943
Replacing cab body mounts. Rear mounts, position #4. Discovered the driver side uses a 15/16" socket and the passenger side uses 13/16" socket to remove the bolts from inside of the cab. Is there some important reason for the 2 different sizes? Thanks.
Old Jul 15, 2022 | 02:50 AM
2001F350dualwheel's Avatar
2001F350dualwheel
If I remember right the body is thicker on some of the body bolts and has a taper. I believe that’s to center the hole on the cab to the hole in the frame. Maybe I’m thinking the bed. I forgot. It’s been a while that I did body bushings.
Christ who knows. Really there isn’t any real reason to have different hex head size on body bolts. The damn driver and passanger windows are different measurements from front to back on the front doors. Maybe the same engineers worked on both windows and body bolts and were mad at each other
Old Jul 15, 2022 | 09:48 AM
acdii's Avatar
acdii
Just a guess, but different heads usually mean different diameter bolts. The driver side might use a heavier bolt due to body flex from engine torque.
Old Jul 15, 2022 | 09:52 AM
ramon1943's Avatar
ramon1943
Thanks, I know different diameters normally have different size hex heads. One video stated that the 2 bolts were different, but not how they were different.
Old Jul 15, 2022 | 10:42 AM
2001F350dualwheel
pretty sure it’s to locate the body to the frame hole mounts on the assembly line. I think the bed has the same bed bolts where two in opposite corners are tapered to locate the bed to the frame
for lining up cab and bed.
Old Jul 15, 2022 | 10:57 AM
ramon1943's Avatar
ramon1943
Thanks you kindly.
rayxxxle
Apr 14, 2021 03:28 PM
pin8246
Aug 17, 2012 06:43 PM
Red Cobra
Nov 16, 2009 03:59 PM
hoperox74
Bronco II
Jan 28, 2009 05:36 PM
TUFFY
Sep 30, 2003 11:03 PM
