Replace driver door handle with rear?
Old Jul 14, 2022 | 10:13 PM
number9xd's Avatar
number9xd
Looking into getting rid of the driver door handle lock cylinder for theft prevention. My truck does not have pillar keypad or sensors in the handle, just a normal XLT handle with lock cylinder.
Ive read about swapping a passenger side handle and the challenges that come with that, but couldn’t I just get a driver side rear door handle to replace the driver door handle instead?
Old Jul 14, 2022 | 10:52 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I wouldn’t remove the only means of entering your locked truck if your fob goes dead. Not smart IMO.
Old Jul 14, 2022 | 11:15 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, even worse a dead truck battery and you're screwed, because you couldn't get in the truck cab, and couldn't open the hood to hook up a jumper either.
number9xd's Avatar
number9xd
I’ll address the dead battery / fob don’t open the door issue. Have some ideas on that. Just first trying to understand if the rear door handle can be used instead of passenger side front handle.
Old Jul 14, 2022 | 11:16 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I doubt the rear handle could fit the front, I don't think they are the same length.
Old Jul 15, 2022 | 08:47 AM
redford's Avatar
redford
FTE Leadership Emeritus
It was a popular modification on the previous generation of trucks with steel bodies, although I always though that Jimmi Jammer plate gave you better protection.
Old Jul 15, 2022 | 08:59 AM
BOSS 379's Avatar
BOSS 379
Old Jul 15, 2022 | 09:01 AM
ToMang07's Avatar
ToMang07
Looks the same to me....
Old Jul 15, 2022 | 01:15 PM
jollyrogr's Avatar
jollyrogr
I think this is a legit mod to do because of how easy it is for thieves to turn the lock cylinder with a pliers. It's a dumb design by Ford. You can't use a passenger side handle though because the action is reversed. To address the dead battery scenario, there are products out there for remote jump starting - I don't see why something like that wouldn't work to remedy that.
smikesF350's Avatar
smikesF350
I wonder if a small round steel piece could been placed between the lock cylinder and the handle would fit. Something like the knock out from a metal electrical box to block access to the key lock cylinder. Paint it black to match the handle and maybe use a dab of silicone or automotive 3m double sided tape on the inward side to hold it in place. That would make it an easily reversible fix.
Old Jul 15, 2022 | 03:20 PM
4wd6.7L's Avatar
4wd6.7L
I thought the problem wasn't access to where the actual key would be inserted, but that they are manipulating the part of the cylinder behind the handle that can be seen when you pull the handle, as if you were going to open the door.
This actually gives a pretty clear idea of what they are doing, and how easy it is.
Old Jul 15, 2022 | 04:00 PM
Magoo22's Avatar
Magoo22
If by chance you have a dead battery you can charge the battery off the starter post. May not be the best option but you will get into the truck. I speak from experience...
Old Jul 15, 2022 | 04:38 PM
jollyrogr's Avatar
jollyrogr
https://youtu.be/9nxfUV6JM5Y
Great video. I think the simplest and cheapest solution would be to simply remove the rod inside the door that's connected to the key cylinder.
Old Jul 15, 2022 | 08:04 PM
cficare's Avatar
cficare
That video is incomplete and fails to mention the Jimmi-Jammer option to completely remove the lock cylinder. I did that on my 2017 and 2022 F250. The new doors on the 2022 F150 changed the surround around the lock cylinder, and hopefully eliminated the chance of merely twisting it open with Vise-Grips or Channel-Locks.
Old Jul 16, 2022 | 09:29 AM
drj564's Avatar
drj564
Why not just remove the rod inside the door? Seems easy and cheap.
