Running wire through firewall in ‘07 E350
Old Jul 13, 2022 | 01:43 PM
tabijan's Avatar
tabijan
I’m hooking up daytime running lights and there’s an option to turn off DRLs when the park brake is engaged. It’s not a must have feature but I’ll consider it if there’s an easy way to run a wire from the fuse box to the cabin. Is there a grommet I can use if I unbolt the coolant tank?
Sixto
07 E350 5.4 183K miles
Old Jul 14, 2022 | 11:14 AM
Mike1's Avatar
Mike1
Best way to figure that out is to look up under by the brake pedal on the firewall from the inside. There is usually a rubber plug in that area where the main harness comes through. Sometimes they have a couple of extra rubber plugs in the same area that are unused you can run a wire through one of those also.
Myfreeford
Electrical Systems/Wiring
Jun 2, 2023 01:04 PM
fordnurse
Nov 4, 2011 04:51 PM
wells2
All Things Towing
Aug 12, 2011 08:12 PM
calsdorf
Aug 7, 2003 01:54 PM
