Sponsored by: Auxito
PCM Location
Old Nov 10, 2003 | 10:56 AM
White_lightnin_f150's Avatar
White_lightnin_f150
PCM Location
Hey Ya'll. Just bought a 2000 F150 5.4L Off road. I was wondering where I could find the PCM. I need to get the keyless unlock code "Push button" for the door handle. The owners manual said I could find it on the pcm. Thanks for the help, Ya'll.
Old Nov 10, 2003 | 11:47 AM
neiz15's Avatar
neiz15
the pcm is on the passenger side kick panel. to remove you have to go to the firewall....remove the battery....and unscrew the bolt that holds on the wiring harness. then go back inside the truck and unloosen the two bracket bolts and the unit will slide right out. hope this helps.
Old Aug 19, 2006 | 07:13 PM
littlelorib's Avatar
littlelorib
check engine light
Hi!
I was wondering if anybody knew if I can "count the # of flashes" on the pcm/ecu like we used to be able to do on older cars. I currently have a 1997 F150 and the check engine light came on. I don't have a OBDII tester, and I don't want to pay a mechanic $40 just to pull the codes. Is there any other way to do it?
THANKS!!
Old Aug 20, 2006 | 06:00 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
This thread is a bit old.....hang around though, someone will be by.
See you on the boards. ….
Old Aug 20, 2006 | 10:30 AM
Racerguy's Avatar
Racerguy
Hi Lori
On these trucks there is no way to get codes out of the PCM without a scan tool.
If you have an Autozone close buy apparently they will scan it for free. Just don't let them talk you into buying any parts until you're sure of what you need.
Old Aug 20, 2006 | 02:29 PM
littlelorib
Cool. Thanks guys!
Old Aug 21, 2006 | 05:05 PM
littlelorib
Check engine light
Hi again!!!
I also meant to ask if the check engine light would come on if just the battery needed water?
Thanks again
Old Aug 21, 2006 | 11:45 PM
Racerguy's Avatar
Racerguy
Nope the battery doesn't have anything to do with the check engine light.
Old Aug 27, 2006 | 11:34 AM
littlelorib
Hi again! =)
I was wondering if anybody knew where I could get a list of the codes? Is there anywhere online i could get them?
Thanks!
Old Aug 28, 2006 | 05:33 PM
littlelorib
Oxygen Sensor
Hi everyone. I wasnt to thank you guys for helping me with my earlier questions. This website is great!
I have another question......
I pulled the codes on my moms 1997 F150 and came up with 5 different O2 sensor codes...P0135, P0135, P0141, and some others. They all referenced
O2 heater circuit malfunction and O2 sensor circuit malfunction..sensors 1 and 2 on Banks 1 and 2.
I am wondering if I am just supposed to replace the sensors...or what? Can I clean them with anything? Will that even help? Or do I need to replace them all? I bout a Haynes manual but it doesn't say where Bank 1 or 2 is.
Please help =(
1993_f350_2013
Dec 28, 2014 07:22 PM
laserchick1
1997 - 2003 F150
179
Nov 9, 2012 10:40 PM
MSF350
Feb 24, 2009 09:56 AM
rambaseball45
1997 - 2003 F150
15
Jan 24, 2009 08:31 AM
smilinallover
New Member Introductions
Oct 6, 2007 04:28 PM
