cleaning buildup in motor
i don't know what to use to clean my 300, 6, F150, 94!
my oil pump screen gets plugged up about every 3 months, i want to clean it but don't know what to use, i have heard and know from 1st hand that using gunk in will take away the the oil in the rod caps, "having blown 1 car up doing that" i have ruled that out.
my Q is what use and how to clean it safely.
please help if u can, i live on limted income of 638 a month, so i can't afford any mistakes.
i did a search but came up empty and i know from reading u guys know your stuff, so plz help if u can, and thank you
when the screen gets plugged i replace it with a new one.
this weekend i'mgonna take off the valve cover and oil pan, then clean it with deisel or gas i guess, what ever is best.
was hoping u guys could tell me.
the oil is ok when i pull it, but the pan and pickup screen has little pellets of oil, and it gets in the screen, looks like fine buck shot, and it's caked on the bottom "none moving part" of the motor, i have not had the valecover off yet.
the oil is not discolored.
hope this helps thanks.
ps; i had a guy tell me to use oven cleaner after i pull the cover and pan, sounded like it was not something i should be doing, therein lies the Q what to use after i pull the valve and pan.
I just use gasoline and a wire brush normally, anything to get it off. Then a clean rinse with gas and wipe it out with a paper towel. Buckshot sounds like some kind of additive coagulating like blood. What kind of oil do you normally use? Try some synthetic oil like Mobil 1 next time. Was there ever any additive put in, like teflon based ones or do you use a teflon oil filter like Fram's?
Ihave heard nothing but horror stories about Penziol. One thing you might try is to change your oil with a decent dino, Valvoline or Castrol, then in about 2 weeks do it again, if you still have that stuff in your oil try it again until it's clean. I bet you anything if you kep cycling oil changes until you get all the Penzoil build up out of your engine, then switch to a good syn you won't have any more problems. Also, I've heard BBK, or Bgk something like that is a great cleaner.
thank u for the info, i do change the oil every month when i get paid and since this truck is all i have!
gonna clean it real good this weekend and go to castrol or valvoline.
thanks for the heads up on the bbk or bgk, i'll look it up and use it with gas.
one more thing will it be allright to power wash it while tryin to clean it?
thanks every one for the help
oh and it does not ever get hot
whats exactly is so bad about penzoil???
http://www.cardomain.com/memberpage/443162
anthonycutler1@comcast.net
