Hydroboost Replacement
Old Jul 11, 2022 | 04:10 PM
Garybelvin's Avatar
Garybelvin
4th Gear
How difficult is it to replace the hydroboost on a 2002 7.3 Excursion? And does anyone happen to have any documentation or a video on the process? I am trying to determine if its worth the $1300 I was quoted or if I can do it myself.
Old Jul 11, 2022 | 05:13 PM
callforfire's Avatar
callforfire
$1300? I'm starting to rethink working on aircraft.
It's a fairly easy DIY.
Unbolt the master cylinder and let it hang, no need to undo the brake lines.
Remove the lines from the hydroboost. Have some rags handy for the fluid.
This is the hardest part, contorting under the steering column to remove the clip from the brake pedal.
Then unbolt the hydroboost from the firewall.
Then install the new one.
I know there's more than one good thread showing this, but this is the first I could find
https://www.ford-trucks.com/forums/1...er-stroke.html
Old Jul 11, 2022 | 09:05 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Very easy job. You can do it.
Old Jul 11, 2022 | 09:48 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Should be the same part as my 01 Super Duty and I got the OEM Motorcraft from Rock Auto last year, think it cost about $200 but I do remember it was better than going to Ford...
Takes longer to get the brake pedal clips off and set properly than the rest of the job.
Get some light bungie cords to hold the master cylinder to the hood latch while working on the boost section.
With coffee breaks and union rest periods it should take less than two hours start to finish.
Old Jul 12, 2022 | 12:14 PM
bwguardian's Avatar
bwguardian
I've had to replace one on each of our trucks...purdy easy straight forward...
good to doo
Oct 15, 2022 03:19 PM
.:1978_Ranger:.
Aug 31, 2014 10:33 AM
dualwheels66
May 17, 2012 02:22 PM
1rocn4x
May 6, 2009 06:34 PM
Powerstrokedlariat
Feb 2, 2006 12:12 AM
