1996 5.8 F-250 Upper plenum
Old Jul 9, 2022 | 07:35 PM
Terdman05's Avatar
Terdman05
I’m trying to get my upper plenum off on my 1996 351w efi. We took out what I believe is all the bolts but can’t get the plenum to come off. The front half lifts up but the back is stuck down and can’t see what’s holding it down. Does anyone have an idea what is could be? I can feel a bolt with my hand but I’m not sure if it’s a plenum bolt. Is there one in the back under the fuel return line? And if so how do u get it out
Old Jul 9, 2022 | 08:21 PM
My4Fordtrucks's Avatar
My4Fordtrucks
There are five hex head bolts and one Torx head bolt. Two up front. Two in the middle and two at the rear.
Old Jul 9, 2022 | 10:25 PM
Conanski's Avatar
Conanski
The torx head bolt is on the passenger side and is only acsessable via the slot in the upper between the front and rear runner groups. You need a 6" long T40 bit I believe it is, or a short bit in a 1/4" socket with a 6" 1/4" drive extension. Nothing bigger than those two will fit in the slot.
scottyd9
May 4, 2022 12:59 AM
jbillz95
Sep 23, 2021 08:50 PM
86fsbronco
1978 - 1996 Big Bronco
Feb 5, 2016 01:15 PM
nflfreak43
Oct 10, 2010 06:07 PM
richard1425
Oct 20, 2003 12:11 AM
