Sponsored by: Real Truck
No reverse lights
Old Jul 6, 2022 | 08:15 PM
J ballan's Avatar
J ballan
No reverse lights
Hello everybody, my 15 F350 has no reverse lights all of a sudden. There’s no power to the bulbs and the fuse in the passenger side kick panel is good and has power on both sides. Also the trailer wiring plug has power for the reverse lights. If somebody could point me in the right direction that would be great. Where is the reverse switch located? Or maybe a wiring diagram? Thanks in advance
Old Jul 7, 2022 | 06:05 AM
projectSHO89's Avatar
projectSHO89
Doesn't have one. It uses a sensor inside the transmission. Yours is working as evidenced by the trailer reversing circuit working.
Schematic is below. Check the feed from the BJB (CLS28, BU-WT) to the reversing lamps. Suggest starting with the 16-pin inline connector C465 near the left rear corner of the frame.
Old Jul 7, 2022 | 07:07 AM
J ballan's Avatar
J ballan
Will do. Thank you very much. I’ll post my results
Old Jul 7, 2022 | 07:38 AM
J ballan's Avatar
J ballan
I should mention that I have a back up beeper tapped into the same circuit. I don’t think it would cause an issue but I’m going to unhook it today and see if that changes anything
Old Jul 7, 2022 | 09:21 AM
projectSHO89
Yeah, that would have been appropriate information to state up front.
Check for wiring fault at the point of the tap.
Old Jul 7, 2022 | 12:29 PM
J ballan's Avatar
J ballan
Took apart the connector at the back of the frame and I noticed the clip was broken on it and the connector was damaged slightly. I had good power to the connector so I cleaned it up really good with brake clean and compressed air. Squirted some dielectric grease in it and plugged it back in. Working good now. I used a zip tie to hold the connector together. Thank you for the help. Much appreciated
Sean Roth
Apr 17, 2021 11:35 PM
Trath67
Mar 19, 2021 08:20 PM
Ricky Melton
Escape & Escape Hybrid
Mar 11, 2019 08:16 AM
F350-6
17
Jun 28, 2015 09:18 AM
drawtiteboy2
2004 - 2008 F150
Dec 17, 2014 05:47 AM
